[ Total Views: 25224 | Total Replies: 244 | Thread Id: 91120 ]
 Pages:  1  2  3  4  5  6  ..  9
Author: Subject:  1967 1300 "Race Bug" - Updated 29/06/2016 Vintage Speed Exhaust!!
Memberchequer57
Threads: 15
Theme: UltimaBB Psyche Red
Mood: Moody
posted on June 1st, 2012 at 10:17 PM
The car needs to go to a specialist though to get all it's toe-in and out dialed in as I have mates who race historic formula vee and they swear by it (remember they have the same suspension basics)
The reason Historic Formula Vee's do that is any scrub is loss of speed, when you only have a blue printed 1192cc engine breathing through a 28 PCI you need every tiny little bit of drag reduced.
Formula Vee, preserving engineering museum pieces in Australia since 1964
Membersander288
"Bolt-on Master"
Threads: 183
posted on August 30th, 2012 at 11:43 AM
Update
The cars racing career has been put on hold for a while now; as I need a 2nd car to get around in.
Today it's having it's Roadworthy inspection - fingers crossed it passes without an issue. :starhit:
I've taken the roll-cage and harnesses out; installed new 3-point belts, replaced the race rubber with street ones and re-instated the bumpers
Shaun
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
posted on August 30th, 2012 at 10:13 PM
That's what I love about a Volksie. Race car one day, daily the next, tomorrow....you tell me :)
Membersander288
"Bolt-on Master"
Threads: 183
posted on August 31st, 2012 at 11:31 AM
hahahaha, not quite a daily the next...
They didn't find anything wrong with the car; but weren't sure about a couple of things so weren't comfortable passing the car!
Fortunately they didn't charge me for this so I'm on the search for another roadworthy man; preferably confident on VW's
any suggestions?
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 12th, 2012 at 08:57 AM
Ok, first rego check failed but now I have fixed all the"issues" and it's going back in tomorrow!
First step after rego is to quieten the mother down; I need some sound insulation in the back and a new exhaust.
By Thursday arvo I should have a registered beetle again! Hopefully I can make it up to Warwick
Shaun :D
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 13th, 2012 at 11:49 AM
REGISTERED!!!!
Can't wait to cruise in her again, hopefully I can get up to Warwick
:tu:
http://i1183.photobucket.com/albums/x463/sander19671988/photo2-1.jpg
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Memberwhatnow
A.k.a.: Henry
posted on September 22nd, 2012 at 10:12 AM
time for some historic road rally's?
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 22nd, 2012 at 02:10 PM
Depends who is asking!! hahaha
I'll be on the look out for events though for sure depending on cost
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Memberwhatnow
A.k.a.: Henry
posted on September 22nd, 2012 at 06:39 PM
the halda offer still stands. the set up is getting close to plug and play bar one calibration gear i haven't got yet. no stopwatchs/clock yet though.
what is the rolling diameter of your front tyres?
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 23rd, 2012 at 08:52 AM
645mm
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Memberwhatnow
A.k.a.: Henry
posted on September 23rd, 2012 at 10:18 AM
165-80/15?
for your future reference, to set up a halda trip/twinmaster you'll want a 136 X gear, 39 Z gear. :)
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 25th, 2012 at 06:49 PM
took the bug for a good run today at sustained speed, and I need to get rid of the current stance!
At the moment the back is down and the front is stock; I really need to get the nose down a bit and perhaps think about a kamei spoiler.
As soon as I reached 60mph + the steering became scarily "light" and with the big winds that Brisbane had today it was difficult to drive at speed to say the least. Slowing to 80kph helped but still no great.
It's strange actually the car never felt ridiculously bad on the track going down the straight but now on the road it's a bit naff... not enjoying it
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on September 25th, 2012 at 10:56 PM
have you had a proper wheel alignment ? what front swaybar and shocks do you have ?
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 09:47 AM
havn't had a wheel alignment; and running a bugpack 3/4" sway bar and bilstein shocks
shock part # 24-000321 - which looking on bilstein's website is suitable for only the rear... link below
http://web1.carparts-cat.com/default.aspx?58=1&38=68401663&36=854&...
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4039  - link to sway bar
I have run the current shocks and sway bar before on the track
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 10:04 AM
actually what I'll do it get the GoPro happening so folks can see it without me having to over describe it
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 11:14 AM
DISASTER!!!
Went to get the car out of the garage; fired her up and then it just cut out; no power.... mmmm been here before
Check battery ..... ok
Check that engine turns over..... nope
Check engine turns over with a spanner ......... nope
mmmmmmm
Check the starter is working using the old screw driver trick accross the solenoid..... noise but no cigar
So, the starter I believe has fucked itself and is now stuck against the flywheel, will pull it out and see whats going on
:spin:
ps the moment the engine stopped I got on the go pro! lol EPIC FAIL!!!
Worst part was getting it back in the garage, just me a hill and some ratchet straps joy :crazy:
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Threads: 556
posted on September 26th, 2012 at 11:17 AM
Try turning the motor backwards to unload the starter, btw how come you didn't get vanity plates? They are so cheep in Qld
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 11:20 AM
Hi Steve,
yeah could have gotten personalised plates as its a once off fee here, but still its money and I just wanted it on the road.
We jagged an almost personalised plate for our Tiguan though; it has mine and her initials!
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
posted on September 26th, 2012 at 11:45 AM
Was the motor running when it stopped, or during cranking?
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 11:56 AM
the motor was running then stopped; just checked the vid! lol
Taken the starter motor out and the bronze bush come out with the starter.... could be the issue I'd say. Hopefully the starter motor isn't kaput
The actual engine does turn over with a spanner too
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
posted on September 26th, 2012 at 12:00 PM
So now with the starter out you can turn the engine by hand ok?
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 12:09 PM
Using just my hands I can't budge it (weak I know), but with a shifting spanner on the bottom pulley nut I can turn it over with some effort required
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 12:23 PM
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
posted on September 26th, 2012 at 02:45 PM
Sh1t that doesn't look good mate. Col isn't far away if you want his # he'll come and help. Give me a call if you need a hand or some input.
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 26th, 2012 at 06:18 PM
PHEW!
problem solved, idiots book to the rescue again! (best trouble shooting guide!!!)
Took out the starter as I said and hook up some jump leads to the bugger to check the solenoid and the starter.
Screwdriver between the posts - wrrrrrrr, AWESOME! ok so not the actual starter
Screwdriver onto the ignition post and - wrrrrrr; the thing is ok
Thank god because I didn't want to spend another hundred or so on a new starter.
Looked at the bush that was in there and it wasn't worn but is very loose in the transmission; and the D-bolt engine bolt thing wasn't looking in good shape; so quick trip to Mick's motors and a new D-bolt and new converter bush (6V trans - 12V flywheel) bolted it up just now and the thing fired up with no issues! The new bush fits in nice and snug in the trans.
cost me $11 to fix!
Was seriously concerned when I couldn't turn the motor over hey! though it had shit it self royally!
Anyway; I'll get the video up of the steering tomorrow so you can see what i'm on about.
F#$king bug just wanted some loving
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 27th, 2012 at 08:50 PM
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on September 28th, 2012 at 06:26 AM
Yeah there's too much play in the steering
MemberSides
A.k.a.: Dave Sidery
posted on September 28th, 2012 at 05:42 PM
Yeah, I'm with Daimo that too much play in the steering.
I'm used to BJ bugs, and I'd normally say steering box needs adjusting (but you say in vid that's been done)... else could be steering box is stuffed, steering box loose on beam or the pitman arm loose on the shaft.
If it was a tie rod end would expect there to be a bit of a noise associated with it. Likewise if was a ball joint, but I don't know K&L well enough to say if could be anything specific to them.
Oh hey - what condition is the donut in, and are the splined joints from box to donut to column all OK ???
My toys
Membertar76
Threads: 95
posted on September 28th, 2012 at 05:56 PM
My bug does the same on the highway feels loose in the steering wheel. I also have directional tyres on the front which causes mine to duck n dive a bit.
Well done with the vid to mate
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
Membersander288
"Bolt-on Master"
Threads: 183
posted on September 28th, 2012 at 06:26 PM
I've only adjusted play between the steering worm and roller and havn't checked or adjusted axial play of the steering worm itself.
The king-pins and bearings are firm to; no play when wiggling the wheels.
The donut is looking a bit shagged but it doesn't appear to be creating the play that is present
I'll have a play with the car on Monday and see if I can come up with anything
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
[ Queries: 40 ] [ PHP: 14.0% - SQL: 86.0% ]
