[ Total Views: 11757 | Total Replies: 69 | Thread Id: 91143 ] |
Pages: 1 2 3 |
68AutoBug
posted on February 4th, 2013 at 11:59 AM |
a local who called here a few years ago used to start His with an electric drill of some sort??
maybe 12 or 24 volt Big Drill???
or maybe had a petrol engined compressor in his 4wd??
He didn't have any power on His property..
OLLY
Threads: 25
posted on March 15th, 2013 at 06:25 PM |
Glad this topic has been covered for me I have been offered two of these . I was unsure about grabbing them but I think I will now,
Room in the shed will be my biggest issue.
Uber Kafer
Threads: 50
Mood: Need a bigger shed..
posted on March 22nd, 2013 at 12:02 AM |
Sensational ! thanks for doing that. Good quality scan as well, it should print out nicely.
cheers.
grease monkey253
Threads: 1
posted on February 24th, 2015 at 07:38 AM |
Hi guys , been a forum member for a few years , but never really posted much. I have recently acquired ex army 3 phase /single phase genny ,type 126a
engine runs fine but when I checked the generator out I have found that both brushes are missing .does anybody know if these are still available and
where they can be sought from? Cheers. Scott |
bendbau
Threads: 0
posted on January 19th, 2017 at 09:17 PM |
Hi,
I had to register to this forum so I could ask a couple of questions about that particular generator. I'm looking at buying a 10 kVa generator
because I need a good powerful generator for an inverter welder. I have found one online and it is an ex army one, same as the one featured in this
thread. Though someone replaced the VW engine with what looks like a Holden Barina (aka Opel Corsa)
My question relates to the alternator itself. It says it is a single phase 10kVa unit. But is it really?
I mean, it's it 1 phase where you can pull 30A or is it three separate circuits adding up to 10kVa?
The difference is crucial as I am working with a welder that requires 14A in use and spikes at 25A on start up.
I hope someone with electrical knowledge can answer that question as it could save me a thousand kilometers drive for nothing if it turns out being a
3 phases generator that only has 3 single phase plugs.
Thanks |
AA003
A.k.a.: Phill
Threads: 39
posted on January 20th, 2017 at 05:29 AM |
The output sockets will tell you. Photos?
I read it on samba, so it must be correct.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
bendbau
Threads: 0
posted on January 20th, 2017 at 06:45 AM |
I wish I had photos of the outlets.
On all the photos I can find on Internet, they always have the caps on. According to the manual that Volumex shared, the main outlet can supply the
whole 10kVa but I can not work out what type of connection it is.
I was hoping that someone either has some details or photos of that main outlet (does it have 3 or more pins?)
Or that someone would know how the generator head is wound.
Edit:
I just read this,
Chapter 1, section 1, paragraph 3:
" Four power outlets are provided for each of the two voltages available from the set. One power outlet, in each case, is capable of carrying the
full output of the set, the other three outlets being standard pattern types, each capable of carrying a maximum of 3.5 kW of power. "
Doesn't sound good. That sounds like a three phase generator to me, unless the three standard pattern outputs are in phase with each other and can be
connected together. A detailed photo of the control panel might be helpful. |
AA003
A.k.a.: Phill
Threads: 39
posted on January 20th, 2017 at 10:40 AM |
Do you wan't three phase or single phase?
Three phase will do either if it has a neutral. (Star wound)
bendbau
Threads: 0
posted on January 20th, 2017 at 01:17 PM |
Hi Phill,
I'm after a single phase, as in, two big wires (in a 10kVa, that amounts to about up to 41A) But I know that some generators are sold as single phase
when in reality they are three phase 415V generators with the 240V outlets wired each between one line and the neutral. But then the issue is that you
can only pull 3.5kVa from each phase, or about 13.8A (and even that is not good for the unit if you don't balance your phases) |
BennVenn
Threads: 1
posted on December 18th, 2020 at 05:23 PM |
For the sake of posterity I've scanned and uplaoded my 15KVA three phase Genset manual. I've got two of these sets, one is a 50/60hz unit with a
different governor than described in the manual. The frequency meter also differs to the standard meter as it has shows both 50 and 60 hz green bars.
The rest of the set is identical to the other 15KVA.
The manual can be found here: https://drive.google.com/drive/folders/1m7Cpz2BWaz3RcKSQjSPnWrZrhaoWAAkA?usp=...
Pages: 1 2 3 |
