[ Total Views: 72402 | Total Replies: 274 | Thread Id: 91278 ]
Pages: 1 2 3 4 .. 10
vw54
posted on June 30th, 2011 at 11:24 AM
Factory Letter 1
vw54
posted on June 30th, 2011 at 11:25 AM
Factory Letter 2 or origional Birth certificates
vw54
posted on February 3rd, 2012 at 04:32 PM
Its taking time but gradual progess is good
h
posted on February 3rd, 2012 at 08:07 PM
Quote: Originally
posted by ian.mezz
Rose says it looks like a old farts car
media whore too by the looks so when are u whoreing eye candy in vwma?
just pics of the car mate as if u are in them craig may need a centrefold
vw54
posted on February 3rd, 2012 at 08:19 PM
I can DO that 4 sure
Have added this pic at the start of the Re Restoration in March 2008
vw54
posted on September 22nd, 2016 at 09:04 AM
The start of the Re Resto
nbturbo
Threads: 89
Theme: UltimaBB Powder
posted on September 22nd, 2016 at 03:40 PM
Very nice car.You have done a fantastic job with that one.
vw54
posted on September 23rd, 2016 at 07:44 AM
under the carpets the Original VW Blue
nbturbo
Threads: 89
posted on September 23rd, 2016 at 03:27 PM
So what happened to the sunvisor? Pretty rare find there.
vw54
posted on September 24th, 2016 at 07:16 PM
That's a funny story I was driving to Valla in about 89 or ?? and a very large truck was coming the other way
the attaching bolts may have been loose the vacuum from the truck pulled the sun visor straight off the car, I pulled over and searched the
surround paddocks but couldn't find it think it got stuck on the truck heading towards Sydney
Never been able to find another one like it was a genuine VW accessory
I am adding some of the body resto pics on Monday so will add them to a previous reply to try and keep in order
Started making some gearbox gaskets today carnt find split case ones any where
nbturbo
Threads: 89
posted on September 24th, 2016 at 08:50 PM
Nothing at CIP1- thought they had parts for everything
vw54
posted on September 24th, 2016 at 09:03 PM
Finally found some enthusiasm and have started rebuilding a split case gearbox for the re restoration of my 56
thanks Gary not as comprehensive as your project
Yeah this is the Re Restoration of my Oval the body has been repaired and painted ( grey n cream ) must add some pics
I knew I had a rattle gearbox ( teeth off main shaft 1st gear ) so re building it to get the pan back together
Its only really the selector housing end cover or nose cone call it what you like
I have good material Klinger paper in 2 thickness and scissors n hole punch
not listed on the CIP site buggar
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on September 25th, 2016 at 06:06 AM
Did you try here, Dave :-
http://www.vintageveedub.com.au/
vw54
posted on September 25th, 2016 at 08:17 AM
come on Greg you probably have a set in the shed for me
Looks like scissors and Klinger material are on for today
vw54
posted on September 27th, 2016 at 12:54 PM
More Body Shell pics
vw54
posted on September 27th, 2016 at 12:55 PM
Metal work finished and at the Panel shop for filler and paint
lardo
Theme: UltimaBB Vintage
Mood: just short of teriffic.
posted on September 27th, 2016 at 07:48 PM
I have a couple of sun visors minus the mounting brackets if your interested.
Neil
vw54
posted on September 28th, 2016 at 07:05 AM
Gooday Neil
Are they full metal like this one, do they have alloy strip on the front
vw54
posted on September 29th, 2016 at 07:50 AM
Gearbox now together just have to fit the axle tubes and backing plates
Progress
nbturbo
Threads: 89
posted on September 29th, 2016 at 09:25 AM
Dave, are you doing the gearbox yourself?
vw54
posted on October 3rd, 2016 at 05:18 PM
Yes have always done split case gearboxes there pretty simple only a few measurements done about 15 or so but not for a while now so had to
put thinking cap back on
the tunnel cases need a jig or cut away box to dummy up
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on November 13th, 2016 at 05:21 PM
Quote: Originally
posted by vw54
Any tips on making gaskets, Dave ?
My '54 box is back together, however I need to make the 'nose' gasket. Thickness is important, as it controls the bearing pre-load.
vw54
posted on November 13th, 2016 at 05:37 PM
yeah Greg that's just what I had to do
I got some gasket material paper type 2 thickness good quality stuff
you need a ring spacer gasket as well to take up the pre load I have patterns and material if you want
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on November 14th, 2016 at 02:00 PM
All done now, Dave. Thanks for the offer though. Those early split-case boxes are nice and simple.
Inside the trans is like new...the odometer shows 22k miles, and, judging by the condition of the car, that's original.
vw54
posted on December 27th, 2016 at 10:32 AM
the Xmas break allows time to do some work on the chassis
vw54
posted on January 2nd, 2017 at 12:54 PM
Chassis nearly back on 4 wheels
had to find narrow brake shoes the wheel cylinders I had Stainless steel sleeved years ago just had to fit new rubbers
vw54
posted on January 2nd, 2017 at 12:58 PM
I measured the rear suspension before I removed it and fitted back the same way 11.5 on the drivers side and 11 degrees on the passenger side went
together easy with new rubbers
sander288
"Bolt-on Master"
Threads: 183
posted on January 2nd, 2017 at 02:19 PM
blast from the past with the Oval, found this on youtube
https://youtu.be/zLxZtkt8RLA?t=1m
vw54
posted on January 3rd, 2017 at 06:31 AM
That's 1990 from memory
Stan had a red light on the start
vw54
posted on January 9th, 2017 at 07:42 AM
More progress over the weekend back brakes on and gearbox filled with stinky oil
