[ Total Views: 19818 | Total Replies: 169 | Thread Id: 96078 ] |
Pages: 1 .. 4 5 6 |
vw54
posted on March 12th, 2015 at 09:22 AM |
Great pics and heaps of work
Can you send me a box of your enthusiasm
D-train
Threads: 40
posted on March 12th, 2015 at 05:06 PM |
Thanks guys, been a fair bit of tinkering with it, more to still happen tho..
vw54
posted on March 12th, 2015 at 06:28 PM |
I HOPE YOU REPLACE THE STEERING JOING RUBBER ???
D-train
Threads: 40
posted on March 12th, 2015 at 09:29 PM |
YES I HAVE!!!
why are we yelling?
D-train
Threads: 40
posted on March 16th, 2015 at 07:37 PM |
It's time..
An out it came
Then in it goes
Mounted all up an visually aligned the wheels.
Test drive was ok, tyres are hard up on the buckets so will sort out the ride height, readjust the tierods, an fine tune the rest!!
Little difference
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on March 16th, 2015 at 09:17 PM |
Hows the ride with the new beam?
vw54
posted on March 17th, 2015 at 07:01 AM |
Wasn't yelling 4got to change the case
So the Judson Oiler was blocked with a hair ball must keep an eye on mine
Have you changed the split case gearbox for the later tunnel type why did you fit a new nose cone ?? do you have the wrap around front mount on
that chassis
D-train
Threads: 40
posted on March 17th, 2015 at 07:15 PM |
it rides ok, need to still dial it in to what i like so hopefully have it done by the wknd.
i knew u wernt yelling.. little joke.
the box was swapped to a 1500 box, the nosecone originally isnt a dougnut style but the later style, but because of the difference in where the cone
sits from split to non split, the nosecone gets replaced with a bus cone to keep the box level and help with gear selection. i did a lot of research
before i pulled it so i knew exactly what i needed to do the swap without having to wait for parts,
Dibsy
Threads: 37
posted on March 17th, 2015 at 08:13 PM |
As always an entertaining read of an awesome Oval, got to be my favourite post !
D-train
Threads: 40
posted on March 19th, 2015 at 07:41 PM |
adjusted the arms for a better ride and fine tuned the height, miss the buckets now unless i go to a smart car tyre..
just need to adjust tie rods and a wheel alignment..
finally its nearly.... "finished"
jobie
Threads: 26
posted on March 20th, 2015 at 09:28 PM |
Very nice car!
Excuse my ignorance but how do you 'adjust the arms for a better ride'?
Joel
D-train
Threads: 40
posted on March 21st, 2015 at 06:29 AM |
thanks Joel,
since its a 6" beam it has no shocks so to make it ride a bit better ive set the arms at a greater distance away from eachother so there is more
tension on the leaves.
the bottom one has been pulled down as far as i could then lowered the car down so i could get the tension on it and adjusted the top to get the
desired ride height making it stiffer in the front.
make sense to you?
jobie
Threads: 26
posted on March 21st, 2015 at 09:57 PM |
Perfect sense. I thought about doing the same on my 56 (4" with shocks) but thought maybe the net result would be the same. I guess my first thought
was on the money. Make much of a difference?
D-train
Threads: 40
posted on March 22nd, 2015 at 05:42 AM |
i did it with the 4.5" i had in there too,
made a difference with the 6" rides better now.
the steering box will come out now, ill remake another quick steer for a different pitman arm to put the old steering box back in, it had no play an
was perfect
1cut808
Threads: 2
posted on April 6th, 2015 at 12:04 AM |
Love the build up. Can't believe your misfortune when it comes to dinging panels on the old girl though...
Very sweet ride!
shaven
Threads: 67
Theme: UltimaBB Powder
posted on April 8th, 2015 at 03:09 AM |
Dion... lovely old girl mate.
And I remember when you were a virgin at all this lol
"When the character of a man is not clear to you, look at his friends"
D-train
Threads: 40
posted on June 10th, 2017 at 08:59 AM |
Bored with all the cars looking the same "slammed on earlies" or with those yuk widened rims. So change is as good as a holiday they say.
1958kafer
Threads: 68
posted on June 10th, 2017 at 12:49 PM |
Wow! Uber cool!
oldskoolguy
Mood: Ticking over nicely.
posted on June 11th, 2017 at 01:33 AM |
Looks great on the move, looks tough.
I was scratching my head - Where did this high riding Bug come from? When I waved on Joyce Street on the school pickup run.
"The best trophies are stone chips"
1969 1500 Beetle "Otis"
2008 Golf GTI
wombatventures
Threads: 44
Theme: UltimaBB Pro Orange
Mood: BUSted, BUGgered & NOTCHed
posted on June 11th, 2017 at 12:07 PM |
Was cool before, now it totally "Rocks"!
Clearance is the new Scraper!
That's the plan with our Topless Super, lift it up and look down on the rest.
Pages: 1 .. 4 5 6 |
