[ Total Views: 4304 | Total Replies: 35 | Thread Id: 96994 ] |
Pages: 1 2 |
Weeds
A.k.a.: Ross
Threads: 22
posted on April 21st, 2013 at 02:15 PM |
Yeah if money wasn't a worry, we would all have our projects completed, in time I will get there
1965 VW Beetle
Weeds
A.k.a.: Ross
Threads: 22
posted on March 2nd, 2014 at 05:54 PM |
That time of year again where I do my little bit of work on the project I never get time for.
Had to replace the fuel line from the tank as it bust open and drained all my fuel. Took the time to replace the fuel filter while I had the tank
out.
Got the car running again and the fuel pump has now started leaking.
So brings me to my current question, do I put a kit through my manual fuel pump, or replace it with an electric fuel pump kit, which seems to be
around the same in price?
1965 VW Beetle
Bizarre
Threads: 730
posted on March 2nd, 2014 at 06:01 PM |
rebuild your original
If you go electric you need relays for wiring changes so as the fuel pump will shut off when the motor has stalled - like in an accident
Electric fuel pumps are really for high flow situations
Weeds
A.k.a.: Ross
Threads: 22
posted on March 2nd, 2014 at 06:04 PM |
Ok, cheers for the advice. The kit looks pretty simple, couple of gaskets, new diaphragm and springs? There are no adjustments I will need to do is
there, just replace items?
1965 VW Beetle
Bizarre
Threads: 730
posted on March 2nd, 2014 at 06:22 PM |
do not believe so
All the "adjustment" in in shimming gaskets under the pump to adjust the distance from the pushrod.
If it worked before it will work again
Weeds
A.k.a.: Ross
Threads: 22
posted on March 2nd, 2014 at 06:29 PM |
Thanks for your help so far. I have looked on some sites for the kits, they talk about hp sizes, can you tell from the image below what type of pump
this is? I believe my motor is a 1600 twin port.
1965 VW Beetle
Pages: 1 2 |
