[ Total Views: 52201 | Total Replies: 372 | Thread Id: 97112 ] |
Pages: 1 .. 11 12 13 |
Flintstones
Threads: 69
posted on August 20th, 2014 at 09:11 PM |
Cool build, it certainly is coming along.
Was looking at this pic and was wondering if there is ample clearance between the body and when the tyre grows in height when you're on the load
pedal?
Quote: | Originally
posted by 20bkombi
20bkombi
Threads: 26
posted on August 21st, 2014 at 02:37 AM |
Quote: | Originally
posted by FROSTY
Very nice!! can't wait to see this in the flesh.
Thanks guys!!
Don't be fooled Frosty, photos always make it look way better than it really is.
I really would like to build a proper chassis car in the future but for now this will do.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
20bkombi
Threads: 26
posted on August 21st, 2014 at 10:04 PM |
Quote: | Originally
posted by Flintstones
pedal?
Quote: | Originally
posted by 20bkombi
It's just the angle of the picture, theres 110mm with all guards on and me in it.
All the guards and bonnet have been fitted and now removed. Also did a quick wheel alinement, and sorted fuel and water lines.
My new Microtech, 4x Msd coils, Msd leads and M&W CDI will be coming up Jambo weekend. I have some customers autos to get out this weekend to
fill in the time.
Ph 0402 233 027
20bkombi
Threads: 26
posted on August 22nd, 2014 at 10:46 AM |
Got up early to bleed the brakes... All done
Sorry no pictures today
Ph 0402 233 027
20bkombi
Threads: 26
posted on August 22nd, 2014 at 10:13 PM |
Nearly finished the fuel system. Lots of $ in speed flow.
Machined down the -20 thread on the fuel filter and welded the 1 1/4 tube to it to save fittings.
Next is to weld another fitting in line for a bosh prime pump, then put a rollover valve on the fuel tank then put the tank liner in to keep it from
rusting.
Ph 0402 233 027
lou0060
Threads: 30
posted on August 23rd, 2014 at 10:28 PM |
nice work Aaron, I'm just so pleased that this thing will run in VW Shootout rather than in other motor class...
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
20bkombi
Threads: 26
posted on September 5th, 2014 at 08:00 PM |
Quote: | Originally
posted by lou0060
I might not make the top shoot out, I only have a 10psi wast gate spring and an electronic boost controller is the very last thing I'll be installing
if there's time.
It will be fun just to have a run at any speed
Wheel alinement tomorrow. I have just a few more things to wire then it's on to building a transmission, diff and modify one of my old converters.
Ph 0402 233 027
joesbuell
posted on September 15th, 2014 at 09:34 PM |
Awesome build!
lou0060
Threads: 30
posted on September 18th, 2014 at 06:49 PM |
2 weeks to go Aaron, how are you progressing? Guessing it is almost finished as you haven't been spend valuable time on here.....
20bkombi
Threads: 26
posted on September 20th, 2014 at 08:44 PM |
Quote: | Originally
posted by lou0060
Yes massive hours being spent in the shed lately, still so much to do .
I'll get some pics up of all the small things that take so much time.
These are all done now. Fuel lines, radiator and water lines, oil cooler and lines, most engine/cdi wiring, throttle cable, intercooler water lines in
the rear ( esky not finished), ice cooler for the auto as well.
I built a basic trans for now just to get the car to the dyno on Tuesday and will build a good one after Warwick.
Tested the converter today, still not loose enough.
A very quick tune (4mins) and it came to 2 psi at 4850 rpm on the foot brake,( needs more rpm to make more boost, it might come up with a bit more
tuning. This will also do for dyno runs and Warwick.
It will be slow of the line as I expected using these two GT 40 turbos ( 2x.96 T4 single entry exhaust housings) they come of 2x 9L trucks now on my
1.3L. The engine should see 10psi at around 5700-5900 rpm on paper but the massive bridge port I've done might alter that a bit.
Ph 0402 233 027
pete wood
posted on May 1st, 2015 at 12:51 PM |
Love to see an update on this.
pete wood
posted on August 27th, 2015 at 01:30 AM |
Came across this on youtube. Does anyone know if he's got any further?
https://www.youtube.com/watch?v=kMTrQlrc1rY
20bkombi
Threads: 26
posted on February 11th, 2020 at 06:21 PM |
https://www.facebook.com/photo.php?fbid=853376508165489&set=a.10804372269...
Ph 0402 233 027
