WTB: dual single port manifolds
https://forums.aussieveedubbers.com/threads/100136/wtb-dual-single-port-manifolds
6621104 ·
as above, for the later 1500 single port heads. type 1 motor. Have carbs (32 PCIB), but willing to consider a complete kit suitable for 74 X 85.5 single port engine. Let me know what you have
grumble ·
I may have a pair in Taree,where are you?
69bug ·
Beetle or type 3?
6621104 ·
For a type 1, not type 3 engine. am in SA
13bwagon ·
you could make some !
grumble ·
I have a pair of type 3 single port manifolds,i used a pair of these on a few bugs over the years by extending them.Pm if interested.
type 1 never had single port mainifolds only type 3 pre 67 or so
as per above you could extend them to get carbies above fan shroud
grumble ·
The first one that i fitted I used Holden carby spacer blocks along with the strombergs,I think 2 or 3 blocks brought the carbs up high enough to fit a straight linkage between the carbs,i have also modified the type 3 centre pivot and used the rods with the type 3 carbs fitted using the spacer blocks..Innovation always works.
6621104 ·
Here's the plan- looking for the vintage speed look - a '66 bus motor, 74 x 85.5 single port dual carb. Manifolds will need to be tall (similar to the okrasa style) to help with air cleaner fit and linkage. I know I could go dual port and would have no problems finding manifolds. Carbs solex 32pibc's. Shorty type 3 style I have and may use them as a start to make my own manifolds.
A set went for around $35 on ebay a few weeks back !
