Trying to sort out an engine combo and so far have decided to go for 1916. How do you work out what size carbs to run? Looking at a W120 cam CB mini wedge port or the Los Panchito heads (need to do a bit more research there). Basically I would like to make 120hp reliably. Any info/advice from those who know is greatly appreciated. Thanks,
Dave
vwo60 ·
Run 44 IDF's, they are very tunable and will make that sort of power with out issue.
Go with the 44's 👍
DubbyDo ·
Thanks guys, wasnt sure if the 44s would be overkill on such a small engine. Means if I increase the size a bit later they will still be useable.
Cheers again
Super1302 ·
just make sure your 44 idf's are not porous, i had 2 brand new sets that were. i use 44 decades off Rod Penrose and they are very well made and put together better i believe.
Lateral ·
I'm running 40mm Decades from Rod on my 2054cc engine (also from Rod) and they are great.
