Anyone know how to remove ankor wax or penatrol off the outside bodywork?? Turps maybe?
RODZ ·
heavy duty wax and grease remover. presol wtc. would get anchor wax off but penatrol would be harder. I have used a product from bunnings in a yellow tin called goo off (i think)that removes everything including graffiti, disolves harded liquid nails/glue etc.
tar76 ·
^ Sweet mate, that stuff woudn't hurt the paint?
viiking ·
Penetrol is at least 68% white spirit and mineral spirit/turpentine. I would use white spirit to start as the other remaining "secret ingredients" are dissolved in these spirits.
RODZ ·
Wax and grease remover or Prepsol, will not hurt the original paint as long as you monitor it and dont leave it to melt the paint (and as long it hasnt been painted after the factoy paint.)
GOO OFF-I used it on the roof of the lowlight to remove the liquid nails that someone used to glue insulation on the inner roof. Nothing else would work, I used it and monitored it as much as possible, but didnt hurt the paint as long as i didnt over do it in areas.
tar76 ·
I'm going to leave it on the roof, but want to get it off the panels and keep them in check with a good buff and carnaubra wax
coletrickle ·
Gibbs oil!does it all cleans degreases protects /rejuvenates rubber,fixes electrical faults!Matty sells it.$88 a litre,Best $88 you'll ever spend.
coletrickle ·
Hay Tarim on a side note I don't think there's much paint left on your car buffing it would unwise IMHO.
tar76 ·
Not for the bug, for the split. Gibbs doesn't remove the ankor wax need more stuff like others have mentioned.
Once off then i want to give the paint a light buff and a good coat of wax (not polish).
Mr Muppet ·
Merry Christmas Tarin, I have Prepwash (Wax and grease remover) 1L you can have if you want. I also have a variable speed buffer you can borrow if you need and a couple of different cutting compounds, you just need to pick them up .
Cheers, Michael.
tar76 ·
Back at Michael. Haven't seen you around dude hows that sick baja of your's going?
Mr Muppet ·
Hey Dude, the Baja is in great nick, just waiting to get down and dirty . Now I'm off work the ute has been parked and its all VW. What's Bribie beach like for cruising down?
h ·
^ michael, a few of us hillbilly off roaders are going for a play tomoro arvo.. roll up
Mr Muppet ·
^ where about's are you heading h ? Sounds sweet. PM me.
