has anyone ever fitted anchor supports for lap sash belts in the rear of a 1969 Karmann Ghia or similar.......if so can I have some tips on where to mount them?....Cheers
empi ·
Mine are in the floorpan close to the sills
rickp ·
my top ones are in the parcel shelf closest to the quarter window, you will find a flat peice of sheet metal there to fit the anchor plates
the lower center ones have the plate bolted through the body and the pan in the small area you have near the gear linkage (under the cover plate)
the lower outer ones are in the metal that is acessible throught the rear door cards
Mika ·
thanks for the replies, looks like i have my answer
