Does any one know where to get twin manifolds for 36 IDF webers ?
These are for the dual port head
Any idea of cost?
tar76 ·
Mate same as 40mm idf manifolds. Try Rod Penrose thats where i got mine for my 36 idfs
waveman1500 ·
Most Weber IDF manifolds are 48mm diameter, which is a lot bigger than you should have for 36mm carbs. Try and get some manifolds which are genuinely 40mm internal diameter, and that will be close enough.
^^ The only true 40mm manifolds are made by CSP and stocked by Vintage 02 97891777
RodPenrose ·
Grasack , I have about 300 used manifolds here priced from $ 70 a set . These are available in 38mm , 40 , 45 and 48mm diameter openings to suit the IDF and DRLA carbs . I also have new manifolds here priced from $ 130 a set if you want to go this way . These are available in many different styles and I would need to know what type of linkage you have . I can also supply a linkage if necessary , ROD , 02-42729920 .
13bwagon ·
rod has everything 🙂
Grasack ·
Thanks everyone for your input
I will contact Rod in the new year and see how we get on
Happy New Year to all
