RodPenrose ·
I have removed a signature 1916cc engine that was in my own car for the last 2 1/2 years . This engine had done around 50,000 kms , was dismantled , inspected and rebuilt with new bearings . I also gave the cylinders a light hone and re-used the rings . I also serviced the heads and it is ready to go . This is a complete turn key deal as removed from the car from the clutch to the new exhaust and will be supplied with the dyno report . Everything was brand new when the engine was originally built apart from the 40mm Dellorto carbs that were rebiuld with an up date kit installed . This engine is the 105 hp deal , can be driven @ 50 km/h in top gear and will rev out to about 5000 rpm's . The torque is really good and will pull up pretty much any steep hill in top gear . This will fit any beetle or early kombi and is built on a universal case . I would like $ 5500 for this engine and is located in Wollongong NSW and can be picked up or freighted anywhere , ROD , 02-42729920
