Gday all!
I'm sorry, *sigh* , but yep I like SP heads.
There you go, my grubby secret is out! 馃槀 Has anyone else noticed (or even cares remotely?) that they are now bloody hard to find? I have seen them on Ebay (first question........), I have seen them from CIP1 (second question........), and every now and then you see them 2nd hand (third question!........).
Q1. I have been told by the experts on the subject who frequent Sa&&a that the Ebay heads are of asian manufacture and therefore utterly crap. I really don't want to go down that path, other than to say they also make brand new BMW bikes better than the Germans (fewer recalls), so I rekn they have the technology. Is that technology applied to VW SP heads however, or is it the cheapest-is-best form of manufacture? Does anyone know for sure? Has anyone tried them out?
Q2. CIP1 say there heads are from OEM Brazil, but I'm fairly certain they stopped making thse SP heads even in Brazil umpteen years ago. Has anyone bought a set in the last couple of years? How was the material density and overall goodness?
Q3. Most of the "newer" SP heads are now damn near as old as me, so their 40th birthday was a while ago! If they are anything like me, these heads also will now be feeling well and truly NOT trim and muscular! Unlike me however, is the general consensus that they are OK for a proper rebuild, or past it? By proper, I mean phosphor-bronze seats, bronze guides, SS valves, quality retainers/collets, new studs, etc?
*sigh*
Yeah, I know. Just stop being a bloody pain and get a set of 043s or 044s and slink away into the corner again.......馃槉
They DEFINATELY have their advantages though over DP, hence the questions and info.
Please.
PS Just so you can argue with your mate at the pub next w/end, ported SP heads on a mild 1641 with Solex30 is 1/2 sec faster down the 1/4 than stock VW 355A twin-ports............ 馃槑
69bug 路
Don't worry also love sp heads.......
68AutoBug 路
Yes, I still have Single posrt heads
I don't really know why
have replaced them with heads from VW head place JAXs
in QLD
but was told they went out of business..
New heads are being made in INDIA and was told they are Good
Twin Port that is... not sure about single ports.??
don't know if there are any new ones about??
and whether South Africa or Brasil or mexico have made them
in later years...??? [in the past 15 years]
bajachris88 路
Nothing wrong with single port.
This lad does 7.6 sec passes on the strip:
He has machined it for 40x40 valves, running boost on 2110cc's, rekons he can fit a golf ball in his ports.
I purchased a set of reconditioned SP heads from www.mofoco.com, they also machined them out for me at 39x35.5 for a turbo project in the pipe line. Came to like $600 something. Threw in a set of HD springs too.
The 'flow' restriction people talk of in the SP engines compared to the DP is said to be 'misthought' as being the head itself, when apparently its actually the stock SP manifold.
Just thought i'd chime in and talk how you ought to be proud of your SP likings haha.
modnrod 路
HAHA!
Onya peoples, I'M FEELIN THE LUV!!!
Anyway, yeah, the restriction is in the manifold stock. "Back-in-the-day" putting on a custom 1.3/8" manifold on a 1500 with a tweaked single 34 really woke them up. If you hate Solex's, then I tried a Mikuni 40mm bike carb that was pretty snappy too. 馃檪
SP heads are hard to beat in some cases, and for me that means when it's bloody hot (it was 49*C on my shaded front porch yesterday........), and when you like an engine that has throttle response like a bike, and excellent fuel economy.
I did also consider small-port TP heads, but apart from Mofoco 040s and Mex EFI 043s nothing really has the velocity for a little stockish motor combined with heat capability, and neither matches the SP that well.
Guess sometimes I just feel like all these little engines aren't having much imagination thrown at them any more, so a SP port single carb mild hotrod would be kinda cool.
rob53 路
I recently installed a pair of new Oem Mexican sp heads, the quality was ok, but the aluminum is definitely weaker. I very lightly bumped one of the heads on my work bench and it bent and cracked a cooling fin!
Next time I would rather find a used German pair and have them reconditioned instead.
modnrod 路
Aaaahh.
OK.
Thanks man. That's the exact sort of feedback I was hoping to hear.
Or not really, but anyway.
Doug Sweetman 路
Don't be afraid to be different !!! I personally am a big fan of doing things differently
modnrod 路
Doug Sweetman wrote:Don't be afraid to be different !!! I personally am a big fan of doing things differently
Good onya Doug!
Different, that's me! Actually, not really, I just like to think that. 馃槀
Although, if you like things a bit different, then when I eventually get the little thing running (and jeez, I hope it doesn't take me 10 years *sigh*), you might appreciate some of it.
If it's not bad enough that its a fatty, it will definately, absolutely have a 2BBL(short list is either Holley350/500 mod or Carter BBD) on a isolated centrebranch intake. I'm even considering NOT running a 4-1........yep, radical I know.
At this rate, I'd be amazed if it even starts, let alone runs!
HAHA! 馃お
Hey man, do you ever get to Alfreds in Guildford with the NOH2O club (oops sorry! collective)?
Doug Sweetman 路
Lol 馃檪 that is different ! But you know what ? It's just an air pump - air and fuel in one end, heat and noise and tractive effort out the other. There's bout a billion different ways to get he air and fuel to the combustion chamber.
Holley 350's seem to be use pretty successfully on the draw thru turbo kits you see around.
I haven't been to any of the Alfred's runs, I used to o bits and pieces years ago when I last had a bug, and hope to get back into the club / collective side of things once I get my new one on the road.
humpty 路
Doug Sweetman wrote:I haven't been to any of the Alfred's runs, I used to o bits and pieces years ago when I last had a bug, and hope to get back into the club / collective side of things once I get my new one on the road.
Or maybe you could grab the Green Meanie off the old fella and bring that!
馃槀
Doug Sweetman 路
Lol I could but its 60km away..... Further than Alfred's !
sander288 路
Jax VW Heads is in Lismore, NSW.
Good source for VW heads I managed to get a set of 1300 Twin port heads which are pretty hard to come by
Shaun
Craig Torrens 路
Has Jax closed down ? I thought someone on here said they had closed some time ago ?
sander288 路
I bought the heads 12+ months ago now; but I think he still is advertising in VWMA
bugzla 路
ive got a set of nos ones here if your interested
modnrod 路
bugzla wrote:ive got a set of nos ones here if your interested
Yep, interested.
PM sent.
tar76 路
I've joined the SP club with the split! Running a 1500 sp mostly stock except for the after market extractors.
What size crabs are you running on your 1500 SP?
modnrod 路
tar76 wrote:What size crabs are you running on your 1500 SP?
Most blokes seem to use the 34ICT Webers, or the twin 40Kads. Both sets seem easy to set up, and work pretty good.
My favourite would be a CB performance centrebranch with a new Solex 34PICT and SVDA.
Beautiful to drive.
tar76 路
Just checked that 34 weber doesn't look bad. might keep it a single carb for now so i'll up my carb to a 34 pict at least. Will probably be the first dub i've owned without a 009 dizzy. Only mod i'll make there is elec ing.
Sorry putting a 30 pict on instead of 34, as i have a 28 pict with a govener on the split SC at the moment. Is a SVDA elec ing worth the coin on a 1500SP?
modnrod 路
tar76 wrote:Sorry putting a 30 pict on instead of 34, as i have a 28 pict with a govener on the split SC at the moment. Is a SVDA elec ing worth the coin on a 1500SP?
