Type 1 manifolds on type 3
https://forums.aussieveedubbers.com/threads/100413/type-1-manifolds-on-type-3
Fastie ·
Would like to know if longer straight and offset manifolds used on beetles fit past the type 3 tin. I've got twin DRLA 40s with short manifolds. The problem is I have to remove carbs and manifold to service the spark plugs.. It's to put it bluntly - a bitch of a job.
Probably easier to get a better sparkplug socket. Stahlwille part # 1052 is the best for VW. Adjustable in length, thin wall to get past all but the worst manifolds. I have had an occasional issue on 1 cylinder with the type 3 manifolds, if necessary, carefully clearance the manifold and you won't need to remove them each plug change.
grumble ·
matberry wrote:Probably easier to get a better sparkplug socket. Stahlwille part # 1052 is the best for VW. Adjustable in length, thin wall to get past all but the worst manifolds. I have had an occasional issue on 1 cylinder with the type 3 manifolds, if necessary, carefully clearance the manifold and you won't need to remove them each plug change.
And those little wobbly socket extensions are brilliant.
Fastie ·
I have those tools. I'm using empi short manifolds.. Perhaps the cb shorty's provide more clearance as these are a no go.
empi ·
I know where there are some CB IDF type 3 manifolds locally,
