WTB; push lock hose
https://forums.aussieveedubbers.com/threads/100431/wtb-push-lock-hose
cnfabo ·
hi, anyone out there know where i can get some dash-12 push lock hose for a good price in oz...deemon tweeks in uk has it cheap but but does not specify length and the race shops here are a rip.....
thanks fabo......
Stanley ·
Go to any hyd hose shop...i.e. Pirtek, Enzed.
I can supply you Phenix Industries hose, how much do you want? Might even be able to get you the 40% discount if you ask nicely... 🙂
13bwagon ·
yup mat is the - bla bla man 😀
cnfabo ·
Hey mat bl bla blblabla bla bla thanks
^^ not to sure, but thanks anyway
humpty ·
WTF is 'push lock hose'?..... Don't you just use normal hose with 'push lock' fittings?.... That's what I have on the POS anyway.
This is a push-lock set-up, not all high pressure rubber hose is designed for this use. It is also important to NOT use hose clamps on a push-lock fitting, the barbs are sharp and will cut through the hose.
Stanley ·
Push lock is actually a brand name (push lok) which i think was a Parker product from memory. A bit like the term Bobcat which is also a brand name.
It was originally used on hydraulic components in low pressure applications like case drains.
