vwo60 ·
I have just installed my new front disc brakes using a set of four spot calipers, the rears are a set of CB performance rotohubs, i have not been able to get a consistant brake pedal, after it was bleed the pedal was good but then after some use it began to increase in travel, i had a look at the calipers and there was no drag on the rotor's and the pads had moved away from the disc's, i ordered a set of 2LB residual valves and installed them today, what a difference, the brakes now have a small amount of drag but there is no increase in pedal travel with use, the pedal has good feel and does not change, if you are having a issue with to much travel on a disc brake conversion a larger diameter master cylinder is not necessarly the answer, if the pads are moving away from the rotor's this could be the fix.
