Anyone know the thread pitch size
https://forums.aussieveedubbers.com/threads/100501/anyone-know-the-thread-pitch-size
cnfabo ·
Hi does anyone know the size of bolt and thread pitch etc of the thread on the t1 IRS trailing arm" for the spring plate" and also the 4 bolts that hold on the torsion bar covers????
Burrelli ·
10x1.5
cnfabo ·
Cheers bro
psimitar ·
did you also mean the bolts that hold the spring plate to the IRS 'A' arm? Those are M12x1.5
wild baja ·
the spring plate to IRS arm bolts are M12 x 1.75 8.8 grade high tensile. also amke sure you use high tensile or hardened washers to get a decent Tension Bolt connnection over the slotted holes
psimitar ·
wild baja wrote:the spring plate to IRS arm bolts are M12 x 1.75 8.8 grade high tensile. also amke sure you use high tensile or hardened washers to get a decent Tension Bolt connnection over the slotted holes
Weird cos the threaded hole in the 'A' arm was M12x1.5 when I put new ones in?
