Type 3 Gearbox v Beetle Gearbox ratios
https://forums.aussieveedubbers.com/threads/100572/type-3-gearbox-v-beetle-gearbox-ratios
XXX-1.8T ·
Hi,
what are the speeds each gear does in a type 3 when you compare to a beetle?
i heard first and second are the same as beetle but third and fourth are longer?
In terms of year I am talking 1964 type 3 vs 1964 beetle.
cheers,
Costa...
1st, 2nd and 4th are the same ratios in both, only 3rd is taller in a type 3 but it;s the final drive that's different and would change the whole overall gearing.
Bugs being 1200 in 63-64 had 4.375 where as the type 3 were geared taller for the 1500 with a 4.125 final drive.
you would need to play around with a gear ratio calculator, tyre sizes change things and needs to be taken into consideration.
