I am slowly tracking down a number of issues with my newly purchase 1967 1916cc beetle.
Whilst having a look under the car I noticed that it does NOT have a Transmission to Chassis Ground strap.
From my "googling" I assume that this is not desirable as it can cause a variety of problems include using the accelerator and clutch cables as "earth" cables that can cause them to heat up!
Also, yesterday I was at the auto electrical place having my VDO electronic speedo fixed and I asked them about the accuracy of oil temperature gauges. I was told that it was very important that they rear of the car is grounded correctly otherwise the accuracy of the gauges will be affected.
Looks like I'm off to Vintage Vee Dub Supplies tommorrow!
Regards
Greg
If it has a solid mount it would not need one
Like in the pic but without the red poly bits
Camo ·
Definitely get one as ever time you start the motor, all the amperage required to the starter motor will be tying to use the other paths that you mentioned.
Kev
Lateral ·
Thanks guys
Bizarre, it uses the standars rubber mounts.
Regards
Greg
bajachris88 ·
I got a strap from supercheap. they have universals... does the job well 🙂
psimitar ·
Yea, Supercheap one works perfectly well 🙂
I think the chassis is M10 stud and gearbox uses M8 studs so if you can't find a strap with those ends then buy one with 10mm holes either end and use a few penny washers on the gearbox lug 🙂
Lateral ·
Thanks guys
Should I use 2 or just one? Is 2 going to be even better than 1??!
Regards Greg
dangerous ·
It is SO important that VW uses a plated stud and nut and washer on the tranny especialy for better conductivity.
Lateral ·
Hi Dave
This is the gearbox that you did for Stenguns back in 2009 for his 1967 car.
I just had a look at the Bentley manual for a 1967 to see where the ends of the strap connect and I can see where it connects to the transmission...where is the best place to connect to the body side of the mount?
Also, is 2 better that 1 strap?
Regards
Greg
Lateral ·
Hi guys
Here is the latest update.
I went and purchased 2 straps and fitted them to the transmission.
I have attached a photo.
Regards
Greg
HappyDaze ·
Wow, that's really getting down to earth.👍
Lateral ·
Yep! I thought that it would be better to go over the top and make sure that I wasn't going to have an issue with a bad earth.
Regards
Greg
hellbugged ·
So you have Stenguns blue car or just the gearbox ?
psimitar ·
that'll keep ya trouble free for many moons 🙂
Lateral ·
Hi Daimo
I have the whole car. I purchased it just before Xmas and am in the process of working through a list of "issues" with the aim of getting it to be a reilable daily driver.
Regards
Greg
hellbugged ·
Ahhh okay..... I passed you when you were driving back south then...... A km or so south of nambucca and gave you a wave from my white beetle.
Good looking ride, was glad to see it out and about
Lateral ·
Ha!
Small world!
Regards
Greg
Lateral ·
Update
I just took the car for a test drive and there is a big difference with the reading on the AMP guage.
Prior to installing the earth straps, it was reading just under 12 volts, now it is reading almost 13 volts.
Regards
Greg
Lateral wrote:Update
Regards
Greg
I remember a beetle that the headlamps [QHalogen] used to go dull when changing gears because it had no earth strap to the gearbox or engine...
I always use a long new zinc plated bolt to go right thru the floor with the earth strap near the battery and the gearbox one underneath so they have a perfect connection..
using the one bolt...
You did a great job.. many people just leave them off when they have the gearbox out... it doesn't have to be a strasp either.. a heavy cable will do..
I make My own from a long battery strap..
another one to the engine doesn't hurt either..
AA003 ·
Lateral wrote:Hi guys
Regards
Greg
I like it when someone does an electrical job correctly!👍
Lateral ·
There's nothing like a bit of overkill 👍👍👍👍👍👍👍
AA003 ·
Lateral wrote:There's nothing like a bit of overkill 👍👍👍👍👍👍👍
That's not overkill! 👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍
That's overkill!
Lateral ·
Also, as an aside, yesterday I was getting my VDO electonic speedo fixed and asked the guy to check the other gauges and I asked him how accurate the VDO Oil Temperature gauges were. He said that the gauges and senders are very accurate that that it was very important that both the front and the rear of the car have a good earth otherwise there will be a difference in impedance and that can cause gauges to be inaccurate....
Regards
Greg
vlad01 ·
dangerous wrote:It is SO important that VW uses a plated stud and nut and washer on the tranny especialy for better conductivity.
copper plated yes?
Bizarre wrote:If it has a solid mount it would not need one
I would still use copper cables or straps to earth out the engine and gearbox to the chassis and battery earth/ground ....
over tiime the steel pieces will rust or corrode which will result in more resistance...
check out the older cars on the road with dull tail lamps and head lamps or one bright and one dull.. etc...
all due to bad earths...
barls ·
i follow the belief below from The Seventy Maxims of Maximally Effective Mercenaries
37. There is no 'overkill.' There is only 'open fire' and 'I need to reload.' (23 February 2004)[45]
Alternate version: There is no 'overkill.' There is only 'open fire' and 'time to reload.' (6 March 2004)(Poster sold by Tayler)
