I have a good used engine here that I have checked out , and is now ready to sell . I have between 115 and 125 comp on all cylinders , approx .008/.009 end float , a Scat C35 cam , a set of dual Kadrons with a new air cleaner kit , new exhaust , new adjustable push rod tubes , and fuel pump .
I have also replaced the rear main seal , oil pump and alt. stand gaskets , all push rod tube seals and oil cooler seals . I have also installed a 51 amp. alt. , new polished stand , 009 dizzy with electronic unit , GT 40 coil , new fuel lines , new 36 HP DH shroud , cyl. tin ect. , set the rockers , and added new oil .
I have started the engine and it sounds sweet , does not rattle or knock , does not leak or use oil . This is complete with the clutch and is ready to run ,
priced @ $ 2800 and located in Wollongong .
This is ready to be picked up or can be shipped Aust. wide , ROD , 02-42729920 .
RodPenrose ·
