Can i fit a reverse light switch to my 67 notch.
If i can where would it go looked at some photos
of gearboxes fitted with them and can't see the
fitting on the nosecone of my gear box.
nsuwift ·
https://forums.aussieveedubbers.com/threads/100683/reverse-light-switch
nsuwift ·
nsuwift ·
matara ·
nsuwift ·
Thanks steve have found a couple of them on the samba ($75) also found another way by attaching a bracket to the shift rod near the coupling and mounting switch under the seat ( would have to be under the car for a type 3). This would engage as soon as reverse is selected not after I am already reversing. My reason for concern is i almost got hit while reversing the other day and if the lights don't come on until I'm moving it may already be too late.matara wrote:Save yourself the hassle of pulling your engine and gearbox and try and locate one of these Hella switches that works off the speedo cable activated when the cable twists the opposite way in reverse:-
nsuwift ·
nsuwift ·
One on aussie ebay for $28 at the momentnsuwift wrote:Thanks steve have found a couple of them on the samba ($75) also found another way by attaching a bracket to the shift rod near the coupling and mounting switch under the seat ( would have to be under the car for a type 3). This would engage as soon as reverse is selected not after I am already reversing. My reason for concern is i almost got hit while reversing the other day and if the lights don't come on until I'm moving it may already be too late.
nsuwift ·
vw54 wrote:You can fit the stock one in the nose cone if you have a hex head plug on it
if not u can pull the box n fit a later model nose cone and the stock switch I did this on my 40hp 65 gearbox works great
I had the hella accessory as per above for a few years but the switch in the nose cone works best
dont like the switch on the tunnel
nsuwift ·
nsuwift ·
nsuwift ·
zocstar ·
