Oval owners I need to check something
https://forums.aussieveedubbers.com/threads/100740/oval-owners-i-need-to-check-something
57 oval ·
Can one of the Oval owners out there please have a look at the bonnet catch and tell me what diam the pin is on the bonnet part of the catch. I am putting mine back together and have found two catches, both different. 1st one has about an 8 mm dia pin with the spring around it and the knob on the end, 2nd one is about 15mm dia. and has a flat side to it, also if it is the bigger there is a slot cut into it does this face the front of the car or the rear
RJ
rose ·
what bit do you mean
rose ·
57 oval ·
The top bit. looks like the large pin. if you look in thru the spring mine has a slot cut into it does that face forward or back ?
grogy ·
mine has the chamfer or flat section of the pin facing the back of the car. i cant see any slot in it
rose ·
no slot sounds like you have cleaned all your parts up and forgot to grease & lube the mechanism back up
