Prototype 40 years old Hybrid Speedo
https://forums.aussieveedubbers.com/threads/100765/prototype-40-years-old-hybrid-speedo
narumi ·
Edited
(wrote it late at night and didn't really make sense)
the 16 x 2 lcd monochrome is the display you might find in some of the vending machine with mostly, green backlight.
There isn't much room to display the units but well, fuel is in percent, oil is in PSI, temp is in celcius and volt.....
I had my old man cutting the speedo backing plate.
it is still on a workbench and will be until I have a day off again. the calibration still needs to be done with the sensors used
this drive the whole thing http://arduino.cc/en/Main/ArduinoBoardMega2560
narumi ·
the $10 16 x 2 display.. which you can probably get for less on e bay
narumi ·
due to the mounting position of the LCD, the backlight needed to be re-position which is a lot of hassle using the good old incandescent globe.
so multiple holes were drilled for the white 5mm LEDs
also the values are simulated, running off of a potentiometer, still need to spend a day or two making the signal amplifier for the fuel sender etc...
donn ·
Right, but I knew all that stuff 🙄
Doug Sweetman ·
Nice ! Cool functionality and self developed, I like it !
vwjon ·
It looks fantastic, very impressive! but what the hell are you talking about?
nils ·
Nice work indeed
SebastienPeek ·
This is freaking awesome!
Arduino's are great fun and make stuff like this quite easy to do at home.
I have a couple lying around waiting for a rainy day myself.
waveman1500 ·
Very impressive stuff!
vlad01 ·
narumi wrote:due to the mounting position of the LCD, the backlight needed to be re-position which is a lot of hassle using the good old incandescent globe.
Nice!, this is the sort of crap I used to do a lot in school and tafe. I build a hand held oscilloscope but the sample rate was crap due to the limitation of the AD convertor built in to the chip. Could of used an external AD with better rates but I was lazy.
Are you using a PIC micro controller?
narumi ·
Sorry for in-activity, busy with work and life and such.
Vlad, it uses Atmel ATmega 2560 on arduino framework
the code I have in there is pretty simple. calibration is hard coded so it needs a laptop for calibration.
it display calculated raw value with no buffer so the values such as fuel fluxuate as the car tilt, brake, corner etc.
the only impressive thing here is my old man's laser cutting by hand lol.
by the way I fried the MCU by feeding 12v into the 5v pin so the laptop won't see the the device anymore. but it still works.
narumi ·
the brain
vlad01 ·
nice. all you need now is to develop a board so you can enclose it all inside the gauge.
Before I read the other comments my thoughts were 'impressive'. Then I see that you have definitely shown a number of people that it is impressive.
If you could develop this kind of work to fit to other old type speedo's then you would have a potential market of street machiners, hot rodders etc that want the info on the dash without the intrusion of 4 extra gauges.
Doug Sweetman ·
+1 what he said....
