I was driving past Rod Penrose's place a week or two ago and noticed this poor little buggy sitting out in the rain. It seems nobody wanted the thing so Rod very generously gave it to me to race on the condition he doesn't have to mow around it anymore.
We've had to make a few modifications to it to fit my 6'3" frame. Morgan has made a nice aluminium seat which Rod will trim before the sydney event and a really small deep dish steering wheel gives me enough room to shift and use the clutch.
We've also chucked a porsche fan on so we can get as many runs as possible in without worrying about the engine cooking.
I've hooked up a 2 step ignition system hooked up to a pressure switch in the brake line, not sure what launch RPM we'll use yet, the upper rpm chip is 8000 I think.
The aim is just to get some laps in at Sydney and get comfortable in the car, might develop the car and sort some issues out with it after that.
We just need to check the wheel alignment and then she's ready to hit the track in a few weeks.
Most of you have seen the car before but here's a few pics anyway http://www.flickr.com/photos/93005116@N06/8453002326/in/photostream http://www.flickr.com/photos/93005116@N06/8451911425/in/photostream http://www.flickr.com/photos/93005116@N06/8453005034/in/photostream http://www.flickr.com/photos/93005116@N06/8453001674/in/photostream
humpty ·
Good score....
20bkombi ·
Cool,,,the old motor I was doing 3rd gear skids and 6000-6500 rpm on the line.
You're in for a wild ride!!!
Have heaps of fun.😀
Aaron
SuperOwen ·
Same motor, it's getting pulled for a freshen up after Sydney.
whathaveidone ·
Are uou gunna run thr jamboree
SuperOwen ·
Probably, I'll see how things go at the VW drags first.
flashrx2 ·
so hav you bought it or just renting for a while?
is a fun ride. i was guest driver at warwick last year.
was the most fun i have had for a long time.
enjoy it!
cant believe it sits outside under a tree.
rod got too many toys.
good luck with it man!
ashley
VWMA Editor ·
It was a lot of fun to build and to race. Aaron and I were quite amazed by how quick (and wild) the car was over the 1/4. Both of us spent a lot of time and effort to get it log booked for SuperStreet, so you should have no trouble sorting the car to make it go even quicker.
One thing we wanted to try but ran out of time to fabricate was a front chin spoiler to help keep the nose down and give more feel through the front wheels. Last year the wheels were hardly touching the ground when it crossed the line!
Oh and if you have a heavy right foot, you can make it wheel stand in first and second gear just for a bit of a laugh!
SuperOwen ·
Thanks Craig, got some ideas for the front but we'll try that later on. Got your message re log books/licence etc and I think it's all sorted but I'll give you a call later just to clarify. Hoping to see plenty of wheels up action on the weekend once I'm settled in the car, I've never driven anything down the 1/4 before despite helping out with some fast stuff over the years.
dangerous ·
You are going to s*&t your self Owen.😂
Please be careful.
Crewing on a fast car does nothing to prepare you for driving , even a low 12 second car.
..except perhaps to approach the car with respect and caution.
Looking forward to the smiles after the first run! 🙂
Dak-A-Tak ·
Should be real fun Owen , has car got front end straps ? a little weight forward will help , bars down hard if rear is soft .
SuperOwen ·
It's got front end straps but they need a bit of improvement. I've got a bit of time now before the next chance to run it so I'll make a couple of minor suspension changes, I want to get some laps in before making any major changes though. We might try a few crazy things on the engine later on as well. Not trying go faster but just test some stuff rods had on the shelf for ages. I'll post up details when it happens.
SuperOwen ·
Finally got some passes under my belt on the car! Unfortunatly as soon as I started to settle down and think clearly in the car it developed a big misfire so no decent times, but still a heap of fun and bunch of wheels up launches. Best of the night was 13.25 @ 99 on a 1.7 something 60. I did end up changing a few suspension settings and the rear shocks and the car went straight and was easy to drive, I just need to work on my shifting mainly. The tech guys want some changes made before next time but nothing too serious so we should be out again in 3 weeks time running all motor at the Jamboree.
A big thanks to Morgan and Ben for there help getting there and back and obviously Rod for giving me the chance to finally do some racing.
whathaveidone ·
Just remember "STAND ON IT"!!!!!!!!!!!!!!!!!!!!!!!!!😂
Was a good night. Been searching for som pics but nothing up yet.
humpty ·
Well done Owen.... Looking forward to see some pics and massive wheel stands!
SuperOwen ·
Found this one, engine wasnt running right from here on on so a bit slow. Had to do a quick bit of wiring repair to get the tail light on in the pits and I think it screwed with the fuel pump voltage. I'll rewire it with a relay and hopefully it sorts itself out, ran an easy 99mph before we did that.
Doug Sweetman ·
Do they race anything other than VL commodores over there ?
SuperOwen ·
After the car failed tech inspection at the last meeting we needed to make some changes to the cage. The taxi bar which the seat belts mount off was too low and the head rest needed improvement. We decided to leave the existing taxi bar in place at the recommendation of the ANDRA head tech inspector and just put an extra one in about 6 inches higher. They also wanted a more substantial headrest so we've welded a steel plate to the cage rear star which will have a padded board attached to it. I'll bring the car back home tomorrow and repaint the chassis while the body is off. The car is also getting completly rewired, moving all the switches and gauges into the dash out of the weather, and installing relays and fuses for all the components. Getting rid of the porsche fan as well and putting an electric setup on so I can cool it a bit in the staging lanes and lose a bit of weight out back.
SuperOwen ·
Just finished loading everything up for the jamboree tomorrow. Spent all week painting the cage and generally tidying things up on the car. Moved all the switchgear and gauges to the dash and rewired everything with relays and fuses. The car Had a grand total of 0 fuses previously, they must have been too heavy... Ended up leaving the Porka fan on it for this meeting but it's getting a new engine combo after this so not sure what direction we'll take with cooling. Not sure what engine yet, the idea of a 1600 with Kadrons is floating around!
SuperOwen ·
Fingers crossed ill be running consistant 12's tomorrow, I'll try post some updates when I get a chance. With the way the car wheel stands we decided the bottom shot was the most valuable sponsor signage 😂 I've actually lowered the bars again so I'm curious to see how it behaves
SuperOwen ·
Just been out in the garage and fitted a Procomp ignition system to replace the MSD Rev limiter that screwed up. The Procomp is a copy of the 6al2 by msd, the car seems to free rev a bit cleaner and smoother with the CDI and the limiter is a bit smoother than the MSD's which was a surprise. These are meant to be a direct copy of the MSD product since the patent expired so hopefully next meeting see's some good passes. Should be out again on sat 27th.
SuperOwen ·
Had a good day at the Test n Tune today. Some minor problems with fan belts flipping off and the 2 step stopped working again (????) but otherwise got 4 passes, all in the 12's. Started at 12.8 and got down to a 12.15 by the end of the day all around 105-106mph.
Apart from a little bit in the 60ft I don't think there's much more in it with the current combo, maybe a 12.0 something if I can 60ft better, 1.65 at the moment? Not sure what it was 60ing when Craig had it. I think it ran a 12.05 last year without some of the weight we've had to add and my 90kg's so I'm happy with how it went.
Big thanks to ben and Rod for their help today.
westi ·
How come the weight was added.
Was it a handling thing ?
Great effort . Where's the vid's
SuperOwen ·
We had to add the extra taxi bar, headrest, porsche fan. It all adds up. I think it was 580 with driver when Craig had it. From memory it scaled at 620 before I welded the bar in so most of the extra weight is me, and I haven't got much to lose. It handles fine now, I'd be quite comfortable adding a bit more power at some stage.
Going to raise the wheelie bars back up a bit before next outing as it hits them too hard and bounces with them set low, sort of an inertia thing I guess with not much power. it carried the front wheels all the way through first nicely the first time out. Also removing the porsche fan and alternator and putting a regular type one style setup on to cure a few issues. I tried Ben's electric fan/shroud and it needs too much hacking up to fit this motor.
We didn't get any vids but hopefully some will show up on youtube.
SuperOwen ·
found one ok pic, last run of the night 12.15@105
13BVW ·
Awesome work on getting the buggy going. I'm about to embark on a rebuild of mine and am wondering if you have any pics of the wheelie bar set up.
Andrew
modnrod ·
SuperOwen wrote:......... maybe a 12.0 something if I can 60ft better, 1.65 at the moment? Not sure what it was 60ing when Craig had it.
Just a quick note Owen.
Remember the 60ft timers are usually (tracks are a bit different) only 3" off the deck. Are you carrying the front past the timers possibly?
If you are then the actual 60ft would more likely be around 1.50...........
LIFE IN THE LOW LANE ·
Aaron is the only one I've seen carry the front wheels out past the 60 foot mark and that was impressive!!
SuperOwen ·
The car wasn't wheelie-ing very much last weekend, that pic was highest it got and didn't carry them very far so 1.65 is accurate. A few online calcs say 1.65 is about right for a 12.1 so it might not have much more in it. I know i can probably pick up a bit on my 1-2 shift at least and the two step still wasn't working so maybe a real high 1.5 something if the planets all line up?
whathaveidone ·
I reckon you had them up past the 60' that friday we took it up!! those wheelys were HUGE!!!!!! and you caried them a hell of a long way!!!!
Lift your bars back up!!!!
SuperOwen ·
Yeah they're going back up to around that height. If you cant be fast be spectacular!!
DavoBuggy 1641 ·
Nice work dude, good to see the buggy has found a good home.
Keep up the good work.
See you at the showdown!
Cheers Dave!
SuperOwen ·
Snuck the buggy onto the dyno this morning just to get a baseline run for comparison after we hot the motor up a little bit after the VW Sydney meet. As a bonus I got an extra 10 RWHP to play with next meeting just from pulling some timing out! Add 1000rpm to the numbers on that sheet for what the engine was actually pulling.
11CAB ·
Wow, 145.6hp from one cylinder.........
whathaveidone ·
Cool!!!!pays to dyno hey. Might see that 11 yet!!! Specially if you use the other three cylinders😁
SuperOwen ·
11CAB wrote:Wow, 145.6hp from one cylinder.........
My secret is out.....
SuperOwen ·
Been tinkering a bit more with the Buggy. Worked out the gear ratios so I could get accurate numbers off that dyno graph, peak power is about 6600 rpm. I've got the two step working properly now and setup on a dial which I can adjust from inside the car. Once we have a working launch rpm I can just unplug the adjustable chip and put a regular one back in so it doesn't get bumped etc.
The cooling system has been changed over to a regular type one setup and another breather line added on the case. Also rewired the o2/rpm logger setup so it doesn't lose the log if you forget to stop recording before switching the ignition off, which has happened every run so far where I didn't forget to start logging....
Rebuilt the rear brakes as well, a blown wheel cylinder had leaked all over the shoes and left me with a one wheel braking system, still stopped ok, just a bit spongy on the lever 😂
If everything works out on the day I'm pretty confident of going 12.0x and maybe even an 11.9, then the engines getting pulled and hotted up a bit for warwick. 🥷
SuperOwen ·
We decided to pull the buggy motor apart for a quick health check before the next meeting. It was running fine but has been together for quite a few years in various cars before the buggy so was due for a checkup.
While it was apart we decided we may as well get a bit more power out of the old girl as well.
Everything looked like new inside apart from some minor cam thrust wear so we replaced them and put the bottom end back together as it was.
SuperOwen ·
The top end changes are a bit more interesting.
Previously we only had 8.2:1 compression mainly due to a really trick set of Fred Simpson ported heads with massive chambers for turbo use. We didn't feel like flycutting a nice set of heads that much so after rummaging through the shed we settled on some old ARPM heads, ported with matching IDA manifolds. The smaller chambers on these will push us up to 10.8:1 and which will hopefully wake the motor up but still be pump fuel friendly (Cheep!!). Had a few issues with rocker clearance but some thicker lash caps sorted that (thanks dave).
SuperOwen ·
These heads should make some decent power, four digit flow figure. 😀
So with more comp, better heads, IDA's and probably a bigger exhaust I'm hoping for a decent drop in times, 11.80's is realistic I think. We'll put it on the dyno next week before hopefully running the test n tune in a fortnight.
cnfabo ·
SuperOwen wrote:These heads should make some decent power, four digit flow figure. 😀
Wow you can Almost put a fist in there,lol........
SuperOwen ·
Might need a some "assembly" lube though. 😁
cnfabo ·
SuperOwen wrote:Might need a some "assembly" lube though. 😁
