Fuel filter replacement
https://forums.aussieveedubbers.com/threads/100803/fuel-filter-replacement
Yogie ·
My beetles plastic fuel filter is leaking (good thing it is not in the engine bay). I bought a new one from Super Cheap Auto and it is a lot larger than the one on there (maybe 50% bigger) and I was wondering if anyone can see a problem with using the bigger filter.
Yogie
barls ·
only that its in the engine bay.
AA003 ·
Only that the fittings will stretch your hoses.
Get one from Mick Motors or VVDS etc.
bugzla ·
if you can use a efi filter they are better but better putting it under the tank away from the motor a 1/4 " filter number z199
Problem with the metal EFI filters and alot of cheap plastic ones is they are 1/4" barbs and stock VW fuel lines and hose is 5.5mm
1mm may not sound like much but the bigger 1/4" hose really need to be clamped down hard for a good fit which it not ideal and using 5.5mm VW hose which is fairly thin walled on 1/4" barbs often makes it split in not much time.
Yogie ·
Can you fit the glass filters from earlier model beetles and will they last longer?
yogie
ian.mezz ·
you just need this type, chip as chips and once it looks dirty just replace it
buy them at repco, autobarn super cheap etc about $5
http://www.ebay.co.uk/itm/Universal-Fuel-Filters-Petrol-Diesel-Car-Marine-In-line-/310073921405
psimitar ·
dunno what hose people are using but I just got some from either supercheap or Clarks rubber. Proper double rubber skin with cotton intermediate braiding.
Then some proper stainless fuel hose clips and not jubilee clips and then a $2 plastic filter above the gearbox.
All slides together with good fit over the solid fuel line and filter and nip up the fuel clips. If using that cotton outer braid type hose then that isn't great stuff really.
Anyhow, that's what I used and had no trouble with it what-so-ever 🙂
AA003 ·
The one on the right is the correct filter.
I really cant understand what the problem is with the people on this forum. Why buy the wrong part and make it fit when the correct filters and fuel hose are cheap and easily available.
Supercheap, Repco, Bursons etc do not sell VW parts. Mick Motors, Vintage Vee Dub, Volksbahn and VW dealers do.
AA003 ·
Yogie wrote:Can you fit the glass filters from earlier model beetles and will they last longer?
yogie
What glass filters?
Yogie ·
There are new empi ones
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D9104
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D9065
or something like these in an older style
http://www.thesamba.com/vw/classifieds/detail.php?id=1377241
Yogie
psimitar ·
AA003 wrote:The one on the right is the correct filter.
Mate, it's fuel pipe. So long as it's the right diameter and of good quality then you don't have to faff around finding a VW shop 🤪
AA003 ·
Where do you get one to suit VW size hose then?
Supercheap, Repco, Bursons etc do not sell them.
psimitar ·
All I know is I bought the pipe at either Supercheap or Clarks and the plastic filter at Supercheap. It's a snug fit on the solid fuel line and isn't overly stretched on the 1/4" barb of the fuel filter.
I made sure of all my measurements before I bought the stuff and so far it's been trouble free 🙂
I use VW shops for a majority of my Beetles parts but for something simple like the fuel pipe a bit of looking around should yield a result but if a VW shop is close to hand then I'd go there too but Micks is the other side of town and I don't do mornings 🙂
x2
good post
AA003 ·
psimitar wrote:All I know is I bought the pipe at either Supercheap or Clarks and the plastic filter at Supercheap. It's a snug fit on the solid fuel line and isn't overly stretched on the 1/4" barb of the fuel filter.
I'm just glad that you're not a tradesman.
Carry a fire extinguisher.
psimitar ·
No I'm far far better than a tradesman cos things I repair and fix stay fixed unlike every QLD tradie I've ever had the misfortune of coming across. 😀
modnrod ·
HAHA! How to win friends and influence people! 🤪
Having said that, I agree. If the fuel line fits snugly, then it's fine.
I can agree with wanting to use genuine OEM VW fuel line too, on the basis that it might be better quality than cheap SuperOne stuff, except that VW fuel line was never anywhere near as good as genuine Mitsubishi braided line as one example anyway, and as we all know the OEM VW stuff has a tendency to split after a few years with engine bay heat cycling, so how good is it really?
Come on guys, it's just a question about a fuel filter, not the relative merits of 1045 pressed vs 4140 machined cranks........
AA003 ·
It's all about size.
VW is 5.5mm.
psimitar ·
Thanks 🙂
I was giving advise from my experience for someone to use if they wished and then have someone who don't know me insult me by saying he's glad I ain't a tradesman.
Aside from the fact I've worked on cars since I was 6 and done most basic trade jobs you can think of so I do have a fair idea what I'm on about 🙂
Nice to hear there are some level headed people out there 🙂
AA003 ·
I just hate to see people getting bad advice.
psimitar ·
AA003 wrote:I just hate to see people getting bad advice.
Seriously!!!! Do you like offending people?
I have as much experience as most mainstream mechanics out there.
So long as the pipe you buy is a good fit and has ISO and other certifications printed on the pipe then it is fit for use. Unless the motors factors buys quality stock then the cotton overbraided hose could easily come from China as the cotton overbraid generally doesn't have labeling printed upon it.
So please stop passing judgement on people you haven't ever met and if you think someones advise is bad then give a response that includes justified reasons as to why the advise is bad. 👎
psimitar wrote:unlike every QLD tradie I've ever had the misfortune of coming across. 😀
psimitar wrote:So please stop passing judgement on people you haven't ever met
Pot calling the kettle black....FFS I've replced SO Much cheap incorrectly sized fuel hose it's not funny. It's worse these days as there are so many idiots with no real training saying things like 'it's ok, been doing it for years....blah blah' ....all over the interweb, so is's gotta be ok......right?.....like f@#k !!
And it's not just a case of....oh its only a fuel filter, what do think most Volksies burn to the ground from.......
AA003 ·
psimitar wrote:if you think someones advise is bad then give a response that includes justified reasons as to why the advise is bad.
I thought that I did that?????????????
Yogie ·
Just thought I would let you know, I bought a universal filter from leons along with some hose and fitted it on the weekend and all is now good.
Yogie
psimitar ·
Matt, it's a case of experience and knowledge. I have used my ability to judge whether parts are durable and well made over many years to fix many things, not just cars, and those things have stayed fixed for decades.
If you know what you are looking for and have an idea how to correctly fit things then you should be fine. If you are a noob then ask more questions so replies can have more detail to help you. Everyone has to start learning somewhere.
If the filter is fitted either under the fuel tank or above the gearbox then you won't have a fire. If you place it in the engine bay with incorrect jubilee clips and piping then you will eventually have a fire.
When it comes to old vehicles you either need to have enough money for a respectable mechanic to look after your car or you learn quickly to fix things yourself. If you try to bodge it or you aren't sure of how to do something properly but give it a go anyway then you 'will' become a cropper.
So blah blah I think I should be good with the repairs I've done. Check my resto thread to see 🙂
