Hi all anyone put these pushrods together before ?
How too... need to be pressed in ?
http://vwparts.aircooled.net/Bugpack-3-8-Chromoly-Pushrods-Set-of-8-p/4053.htm
gotthebug65 ·
https://forums.aussieveedubbers.com/threads/100817/bugpack-38-chromoly-pushrods-how-to
gotthebug65 ·
66deluxe ·
gotthebug65 ·
matberry wrote:You need to work out the length and cut the pushrod to length, then press the ends in using two old lifters. A hammer works, a press is better.
gotthebug65 ·
66deluxe wrote:Use two old lifters to support each end then tap the end in by hitting old lifter with soft face hammer.
gotthebug65 ·
matberry wrote:You need to set rocker geometry and then pushrod length, but IMO a wouldn't be running 1.4 rockers with a stock cam, also 1.4 rockers need lash caps fitted.
hellbugged ·
gotthebug65 ·
hellbugged wrote:Yeah but highly likely you will need different length pushrods when you go to 1915
vwo60 ·
gotthebug65 ·
vwo60 wrote:It is good practice to machine the push rods in a lathe to get the square on the ends.
Lucky Phil ·
SuperOwen ·
