Okay so i have a leak under my gennerator stand and have the gasket to replace it but just wondering how much oil should be coming up thru the breather hose? it is a stock set up type 1 beetle motor 1600cc TP and it is sparayin oil out the air box (74 onwards beetle airbox) is this just because i dont have an filter element in it atm? or is there a problem with my engine?
From Dylan
grumble ·
Hi Dylan did you put the deflector plate under the generator stand?Which way did you put the baffles? Normally not much oil comes uo the hosr but if the crankcase pressure builds up it will blow out and make a mess.
DylanTheDubber ·
What Can cause the crank case presure?
what can i do to ease it? i may have forgot to put the deflector plate on :O
im pulling it appart tomorow to sus it out. how do i get the genny out?
From Dylan
It's probably just the gen stand baffle plate in the wrong direction like Les said.
If the louvers are facing down and open to the left or up and to the right the crank throws oil through it up the oil filler.
the plate needs to be louvers down and open to the right,
ian.mezz ·
check youtube
beetleboyjeff ·
Yeah Dylan, there was a fair bit of smoke coming off the collector area of the extractors when you left Cooperabung today. I was going to talk to you about it.
grumble ·
Do you still have your spare engine?
DylanTheDubber ·
No unfortunatly i don't have my other engine, im pulling the gen off and the stand to check the plate, engine going great other wise appart from exhaust leak, the oil and rich jetting.
From Dylan
DylanTheDubber ·
just fixed the oil leaks from the fuel pump and genny stand, and now no oil leaks onto the exhaust and does not burn and smoke, although there is a pipe that goes from the oil filler to under the car and it puffs and smokes not as much as it did but it still puffs and smokes, what could cause this? the engine is performing great appart from being too rich atm??
