Power Pulley???
https://forums.aussieveedubbers.com/threads/100887/power-pulley
sander288 ·
Hi Guys;
Seeing that I've got a weeeee 1300 I wanted to waste as little HP as possible; so was considering getting a power pulley.
I know the EMPI variety all require a sand seal that either machines in or bolts into the front of the case; I don't like the sound of this so was looking at some other pulleys.
The ones below have a steel hub and grooves like the stock pulley. Do these pulleys need a sand seal or any changes to the case? I.e. do they install like a stock crank pulley?
The other cooler option is the 356 pulley (see link to Flat4 Japan... you'll need google translate). I'm not sure how big these pulleys are though
http://www.cbperformance.com/ProductDetails.asp?ProductCode=2020
https://www.flat4.co.jp/products/detail.php?product_id=6995
the sand seal on the empi pulley pushes in......it doesn't need bolts or mods to the case.
bajachris88 ·
its a sleeve
But a sand seal is a weaker pulley. Most aftermarket have incorrect dimensions on the crankshaft ie loose fit that can wreck cranks. Go steel hub JC or Berg IMO
69bug ·
I've bought a gene berg one,
Could not be happy has made a huge difference to the motor
I bought a Berg for the motor I'm building atm......quality is excellent.
sander288 ·
Did you guys get the achiever or equalizer pulleys?
I bought this one.
http://www.geneberg.com/product_info.php?cPath=7_3036&products_id=3050
not very good for the street, but should be good for hillclimbs ! 😎 😂
ClockworkMonkey ·
What does changing the pulley size actually do? More hp or better response, something like that?
sander288 ·
It slows down the fan so that when the engine is rev'd your fan is still cooling efficiently; its ideal for motors that sit above 4000rpm most of the time. Your basically not wasting power on turning a fan more than you need to.
Alot of vee guys run their fan belts loose to waster as little hp because their rules don't allow power pulleys.
http://www.geneberg.com/cat.php?cPath=7_229_2836
Had a look at the pulley Craig; seems a little small for a roundy roundy car; the other power pulleys are 5.7in from what I can gather
69bug ·
I got the one that is a standard diameter, but balanced.
empi ·
why do it to a 1300?
sander288 ·
My 1300 isn't stock 👍
hellbugged ·
Power pulley sized achiever for you Sean..... But I would go to dog house cooler if so
I run both achiever on the stocka and equalizer on the hotty.... Both stock size
Don't expect to be able to swap out at the track, they are a tight fit and don't come off without pullers
sander288 ·
Thanks for the help fellas
Gracey ·
I've used a Berg pullley in the past, great quality however super tight fit, as said above you'll need a puller to remover.
I've got a Scat alloy power pulley that I use and it's a good fit, about the same as a std pulley, I got it from Aircooled.net.
