Hey guys ,
As I am a green horn, what does a narrowed beam do? And do I need one?
turboty ·
https://forums.aussieveedubbers.com/threads/100904/what-does-this-do
turboty ·
MISS VDUB ·
Doug Sweetman ·
psimitar ·
Birdman ·
vlad01 ·
yup and they roll over easy.Birdman wrote:And they turn your car into a tricycle!
57 oval ·
empi ·
Try doing one before you comment Vlad..vlad01 wrote:yup and they roll over easy.Birdman wrote:And they turn your car into a tricycle!
empi ·
Most narrowed beams will have a shock tower and new end plates, if you do choose to do one my advice is get a scratch built one.Doug Sweetman wrote:Narrowing the beam means cutting the front torsion bar housing shorter, which reduces the front track (distance between the front wheels) and puts the font wheels further inside the guards.
I'm not a big fan of them, it's a mod done pretty much solely for looks and doesn't (in most cases) add any functionality. In extreme cases, sometimes the beams are cut down to the point when the shock towers are removed - no front shocks is dangerous.
Having said that, done well it can look pretty good on the right car.
vwo60 ·
psimitar ·
I believe, from memory of reading the NCOP, that the track cannot be modified by more than 25mm in either direction. Been a while so could be something else it related too but fairly certain was the track width 🙂vwo60 wrote:Make sure any mods for your vehicle are legal and engineer approved, a lot of people have cars fitted with a narrowed beam but it is not legal to narrow the track, i just removed a narrowed beam from my ghia and there is very good improvement in the handling and ride department. i think the lowest ride height allowable is 100MM
