fUCH'S FOR SALE SOLD
https://forums.aussieveedubbers.com/threads/100917/fuchs-for-sale-sold
vwo60 ·
I have a set of fuch's for sale.
6" x 16", p# 91136102043, ET + 36mm.
7" x 16". P# 91136102044, ET + 23mm.
The 6" are fitted with 205/50/16 falken semi slicks and the 7" are fitted with 205/55/16 falken semi slicks. they have about 70% tread left on the four tyres, they are fully detailed and are in very good condition, these were fitted to my 60 Karmann ghia, it has been converted to IRS and it had a 2" narrowed beam, the wheels and tyre's all fitted under the standard sheet metal without rubbing, there is also another set of 205/55/16 semi slicks to go with the wheels, the 2" narrowed beam is also available to go with the wheels if required and can be worked into the sale. wheels and tyres are at Pomona, Queensland.
Cost $1200
Contact Shayne 0754851841
vwo60 ·
The 6" rims
alansvw ·
Did you sell the 2"narrowed beam?
What wheels are on the ghia now?
vwo60 ·
All sold pending payment, i had some 17" composite wheels made so i could fit a standard width beam
Yogie ·
Love the new wheels. What are the sizes and offsets and who made them up for you?
yogie
vwo60 ·
6" x 17" on the front, ET 55MM, and 7" x 17" on the rear, ET 23mm. had them made in the UK at image wheels,
http://www.imagewheels.co.uk/index.html
Yogie ·
Thanks for that. Would you be able to fit 7" under the fron with the standard bean do you think?
yogie
vwo60 ·
you could but you will loose some lock, i am about to help a friend do that, what size tyre are you looking at, they are a 195/45/17 on the front, you can over tyre them, you could fit a 205/45/17 but it would be a tight fit under the front guard. the wheel manufacturer might run into problems with the front half of the rim, they could have done a et of 60 on the six inch rim but then there were problems machining the center as it would have had to have a thicker billet, with the 7" rim you could split the difference.
Yogie ·
I have some Porsche 17" x 7" twists with et55 that came off a ghia in the UK but it had a narrowed beam. I was looking at the 205/45/17 tyres as well but could look at 195s instead if it helps fit with a standard beam. I am not real sure about driving a narrowed beam car as I have never driven in one before so have nothing to judge the handling side of things.
Yogie
vwo60 ·
Its a step backwards if you are trying to get the car to handle, really 1" is a fair bit extra width, particuly on a ghia, the 7" i have are also a ET 55MM and have temporarily fitted them to the standard beam on another ghia, this has 944 brakes on a link pin front end so it will be different to yours, they do not hit the trailing arms but will hit the trailing edge of the guard when turning, it would also depend on your front end and brakes, i have after market brakes on a link pin front end so i have made allowance when i worked out the ET for mine and the compromise i made was to fit 6" rims.
Yogie ·
My front end is ball joint with boxter non S calipers and rotors and the rear also has non S calipers and rotors.
Yogie
vwo60 ·
Have you tried the 7" twists on the car as it stands.
Yogie ·
No as it is still sitting there with the 4 lug wheels on it and I have no tyres yet for the twists.
Yogie
