Decompression
https://forums.aussieveedubbers.com/threads/101019/decompression
Newt ·
Hi Guys,
Im putting together a 1955cc engine.
Heads have been heavily fly cut to (from memory) 35cc.
This brings the static compression (with a 1.5mm deck) arround 11.5 (and dynamic around 10).
2 questions.
1) On a VW is there much difference between forged and cast pistons.
2) Is there much difference between running dished pistons and a wider deck height?
2B) Any thoughts on dished pistons. I did see on the net Toyota 1AR-FE pistons are about right (-27cc) (90mm with 22mm pin) which could come in a 0.50 oversize. Any other options.
Just pondering at then moment as I am in Perth for a month (away from my shed).
Newt
SuperOwen ·
If it were me.....I would hemi cut the chambers and blend the left over chamber into the hemi by hand. Be prepared to run a bit more advance.
^ me too, Don't go more than 1.5mm deck IMO. Converting pistons can be a pita, and not always successful.
