Door hing pin replacement in Brisbane
https://forums.aussieveedubbers.com/threads/101044/door-hing-pin-replacement-in-brisbane
70 Jafa ·
I would like to replace at least the top door hinge pin (drivers door) on my 1970 Beetle, so I am either after someone I can pay to replace it for me or someone that will lend/rent me a pin puller and possibly a reamer. I do not want to repaint the hinge/door so I am after a tool like Roger at Southside borrow last year to do Craig Hugh's Beetle, have spoken to Roger, he can not get a hold of the tool again. Any suggestions, ideally Brisbane Southside, or someone that is prepared to send.
Thanks Rob
steve burgess ·
The easiest way to get a door pin out is to use a air chisel.Grind a tool to suit the job .
70 Jafa wrote:I would like to replace at least the top door hinge pin (drivers door) on my 1970 Beetle, so I am either after someone I can pay to replace it for me or someone that will lend/rent me a pin puller and possibly a reamer. I do not want to repaint the hinge/door so I am after a tool like Roger at Southside borrow last year to do Craig Hugh's Beetle, have spoken to Roger, he can not get a hold of the tool again. Any suggestions, ideally Brisbane Southside, or someone that is prepared to send.
Thanks Rob
Keep asking Rob
I'm sure there would be someone with the VW hinge tool around Brisbane...??
they can be replaced without damaging the paintwork if done carefully...
using that tool or a copy of it...
Those original hinge pins are VERY TIGHT.... and need a lot of force to push them out....
BUGBOY ·
I have one but i'm in Victoria. Its a heavy tool to post all that way I would think.
70 Jafa ·
Thanks for the comments guys, but Iam still looking for a tool I can borrow, or someone that can do the job for me in the Brisbane area.
BUGBOY if you do not mind could you weigh your tool and get a quote for postage to 4163 off Auspost's website.
