They have a Victoria branch, but aust website seems to be gone now...
try REPCO...
or maybe an off road 4Wd parts shop...
someone must have them...
FLAPS is used on USA websites..
I waited until someone else asked what it was.. lol
I only knew it was Your local auto shop.. lol
vwo60 ·
i have a set of golf radiator muonts that i think are the same and have seen them in the states from several suppliers
13bwagon ·
cable ties 😀
Lateral ·
Thanks guys,
I may need to make them up myself if I can't find them..
Regards
Greg
SunshineKarmann ·
Not the best place for that carter fuel pump dude. Should be up under the fuel tank - those pumps are best located so they can push fuel down the lines rather than suck. Most probably will lead to early failure.
Lateral ·
Fuel Pump???
I think you are looking at the fuel filter on the left of the photo.
Greg , remind me tommorow when you are here and I will give you some , ROD .
Lateral ·
Thanks guys,
I know that I can get short ones...I'm after the longer mounts.
Looking forward to our chat tomorrow Rod 🙂
Regards
Greg
vduboy ·
Hi mate most two stroke motorbikes use them for expansion chamber mounts, they come in all sorts of shapes and sizes might be worth a look?😎
Lateral ·
Thanks mate!
vlad01 ·
I just use GM ones, they pretty much exactly like those in the pic and are of better quality than most off the shelf ones. I think mckay make then too?
Lateral ·
Hi vlad, where can I get GM ones from?
vlad01 ·
from holden, if they are still available if not try mckay ones as mckay make most of the aftermarket rubber parts these days.
or a wrecker, ask for VN- VS air box mounts, should be millions of them at a wrecker but new is always better.
