It has been suggested that one should have an oil cooler on any VW in Australia, plus I have also read about fitting external filters for better engine life.
So with a 1600 motor in a bay kombi, how does one go about fitting one? The engine mount is seemingly too close to the oil pump to fit a full flow cover, but apparently it has been done before so how do you do it without wrecking your engine mount bar? Also where do you run the return oil line and where do you mount the cooler and do they need some sort of cooling fan to work effectively? Do they make a kit that piggybacks off the original cooler under the shroud? That would make the most sense.
And filters, can you mount filters on the same line/run? Before or after the cooler or does it make no difference.
Lots of questions I know but thats why I'm asking the experts.....hopefully!
pfillery ·
