need to find 1.9 water cooled
https://forums.aussieveedubbers.com/threads/101197/need-to-find-19-water-cooled
grimbear64 ·
hi guys i am looking for a 1.9 block or running motor for a 1985 caravelle any help would great have case but the head bolts are shot cheers michael
pretty sure you can buy new head bolts from the US but there expensive and geting the old ones out is extreamly hard
A 2.1 T3 was smashed up see this post. http://forums.aussieveedubbers.com/viewtopic.php?tid=101062&page=1#pid946101
I think they are going to part out the car.
dangerous ·
Pretty sure mick Motors stocks those studs.
If not,
you could try Raceware. They used to make a special stainless steel kit.
Hi Dave
The hard part is getting the old studs out, apparently its easier if the motor is freshly opened up, once the case dries out they lock in harder.
dangerous ·
The ones I have done I cut them off close to the case with a 90 degree air grinder,
then drill them out and re-tap or case saver if needed. M12 x 1.5
YES a real pain in the AR$E!
grimbear64 ·
It's the cost then redrill so thought grab another motor put it in mmmmm
