Engine combo stats vs Expected Horsepower
https://forums.aussieveedubbers.com/threads/101215/engine-combo-stats-vs-expected-horsepower
RAW069 ·
G’day fellow Veedubbers
I am new to this forum, but by no means new to the VW scene.
The reason for my post is to gain opinion on engine combo vs expected horsepower.
I recently had my brand new engine dyno’d which confirmed my suspicions that the engine was putting out less that expected.
I will list my engine specs below if I can gain feedback on:
- What horsepower I should expect
- What I can do to find any missing ponies and/or improve HP
- What loss through the trans I should be expecting
The engine is in my 69 beetle which I am building for street/weekend use, but want some really decent power while also having good driveability. I am happy where the power is currently between 2500 and 6000, but just expected more.
Engine is 2165cc
- 78mm CW 4340 Crank
- Lightened Flywheel
- Standard length I Beam Rods
- Engle W120 Cam
- 1:1 ratio rockers on solid shafts
- MOFOCO 050 Heads, 42mm Intake/37.5mm Exhaust, Port and Polish, supposedly 155 cfm @ 0.450 lift, Match ported manifolds **
- 9:1 CR
- 44 Weber IDF’s, 36mm Venturi’s, Air correction: 200, Main jet: 140, Idle: 0.60
- 1 5/8 Inch tuned A1 Sidewinder exhaust
The engine put out 106HP at the wheels @ 4700 and a pretty flat torque between 2500-4500 of approx 120NM at the wheels.
I run 205 60 15’s on the rear and the trans has a heavy duty diff, 3.88 r+p with Welded 3rd & 4th gears.
Usually HP loss is in the vicinity of 15% at the wheels, which means I am seeing 125HP at the flywheel.
Dyno read out attached FYI
** I matched the manifolds myself, as they came standard. These were in the kit from Redline, I have wondered about the restrictive nature of the manifold further inside about half way up to the carbs. From what I can measure it is more like 32mm diameter inside here – is this something I should look at also?
Any advice would be much appreciated.
I think it would also be useful if a thread was started which detailed engine combo and HP output.
Cheers in advance
Cam
modnrod ·
A couple of quick ideas, the really basic stuff, with lots of fudge factors for the real world! 😂 The proper maths to do it is accurate, but takes pages of crap for formulaes.
Head flow at valve lift in CFM@28" (minus 10% fudge factor) = expected and likely HP.
Engine capacity x engine state of tune will give expected and likely torque, multiply/divide by expected HP peak rpm to get power.
Optimised race motors = 80lb/ft/L.
Really good motors = 72lb/ft/L.
Street good motors (eg 4V Honda, etc) = 65lb/ft/L
Older stock "dinosaur" motors (like stock ACVW & 186 Holden) = 60lb/ft/L.
Head flow at 0.435" lift is probably 150cfm, -10% = 135HP.
Street motor 2.165x60 = 130TQs, expected peak I'd guess at 5500. therefore expected HP = 130 x 5500/5250, which = 136HP @ 5500.
Check the manifolds first. That 32mm intake restriction effectively means you've made your carbs into 40IDFs with 32vents. I would aim for 44mm at the carb end, then match-port the manifold end with a gradual taper all the way down to the head. Then make sure the air filters flow enough air for the carbs (air filter flow equals Pi x diam x Ht x 6, eg a 6"round x 3" tall filter flows 340cfm........when perfectly new and clean).
dangerous ·
Did you 'tune' it on the dyno, or just check the power level?
Without knowing the pressure drop at which the heads are flowed
with YOUR manifold and carb,
you are just guessing at this point.
Once you have got the tune correct,
Then you can work out where you need to make some gains.
Even if it flowed that 155 figure with the carb and manifold,
it would never make more than about 155FW if that number was at 25" pressure drop.
...well unless the planets align.
Minus your 15% gives you about 132 wheel.
I have seen between 10% and 15%.
Some engines do make as much or even a little more
than the same HP as CFM at 25",
but this is not often with VWs since there are many things difficult to optimise,
and most owners dont use the dyno as a tuning tool.
My guess is tht with manifold and carb it would be a lot less than the 155cfm at 25".
dangerous ·
Also perhaps some one familiar with IDF's can chime in,
but that jetting will probably go lean up high.
What does the mixture curve look like?
Sides ·
Jetting wise... a 140 main and 200 air on a 36 vent am pretty sure will be going lean'ish from about 4500 up. Probably not break stuff lean, but definitely out of the power lean.
I also think your 60 idle jet is covering up the lean main down low... esp if your torque and power dip at 110 equates to 3000-3500 or so rpm... idles transitioned off before main has really started to kick in.
I'd be thinking 55 idle, and a 145 or possibly even 150 main with that 200 air, but yeah - having an AF curve would be a real big help.
I know from both my IDF days and now the EFI that tiny changes in AF can really hide or unlock power... like getting from 119 to eventually 132rwhp just by changing jets and vents with a prev incarnation 1915.
Plus restrictive filters (Uni) to flowing filters (K&N) can be 4-5rwhp alone.
RAW069 ·
modnrod wrote:A couple of quick ideas, the really basic stuff, with lots of fudge factors for the real world! 😂 The proper maths to do it is accurate, but takes pages of crap for formulaes.
Interesting response thanks. I will have a look into the manifolds and the potential to clean them out a bit more. It is good to confirm what I have been thinking with this.
In regard to your reply regarding flows through the head, basically the outcome of what you're saying is that if I want more grunt I need more flow from the heads. From what I have seen 155 cfm is on the low side for heads with 42mm intakes.
Any recommendations on the sort of flow I should be looking to achieve to get up around the 160+HP while still being drivable and not having to rev too much?
RAW069 ·
dangerous wrote:Did you 'tune' it on the dyno, or just check the power level?
Cheers for the advice.
I did have it Dyno tuned, and this resulted in rejetting and setting timing. This was in conjunction with a exhaust gas analyser.
It was running rich previously.
The tuner was a reputable tuner with previous VW experience.
You are also making me think more about looking at the flow through the manifold.
What I am concerned with here is reducing the wall thickness too much.
Does anyone have any recommendations on an aftermarket manifold for the 44 IDF that has more meat or is alread opened up for better flow for the 44 IDF??
'Cheers
RAW069 ·
Sides wrote:Jetting wise... a 140 main and 200 air on a 36 vent am pretty sure will be going lean'ish from about 4500 up. Probably not break stuff lean, but definitely out of the power lean.
Cheers, more good advice!
I'll have to check I can't remember exactly what it got changed from to the current state, but I think I did have 155 mains in there with the 60 idle - and it ran rich as - everything sooted up - but this could be explained by not enough air flow, am I correct??
132 rwhp is pretty decent from a 1915... what heads/carbs did you have
I do want to get a decent amount more power - basically want to unlock the potential of the 2165. Should I be starting with working from sorting out the heads/manifold to get more than 155 cfm?? and then look at working on the flow of the carb (bigger vent) and then jetting last?
Cam
modnrod ·
Those Mofoco heads are OK for what they are, despite the "web experts" saying otherwise. The casting quality is very good. Don't confuse as-cast with mild CNC work 42 valve flows with the stuff you would expect from a decent race-blended ports. You could easily spend another $600-800 just to pick up an extra 15HP over 5000 where you hardly ever spin it up to.
If they flow 155cfm @ .450", they might also flow 165cfm@.500" as they are (and I would expect flow to keep rising at least to 0.550" lift, and you can access that extra flow with 1.25 rockers on what you have (they do work well on Engle120s).
4700 is a bit low I think for peak HP with those components, but where the maybe-missing 600-900RPM and 20HP is I'm not sure. That's where the fun starts I guess!
There certainly a lot to consider, I agree that the intakes are an area for improvement. I have built a few 2165s and around 100hp is common, but with smaller cams and less compression so certainly something is amiss with your package. What deck height have you set?
Personally, I keep away from 1.25 rockers, but leads to the question of what valve train do you have, rockers, springs and pushrods? Possibly your running out of lift due to problems there as 100rwhp from a 2165 with 40 IDFs and W100 with type 3 super short manifolds and 8.3:1 CR was a recent build of mine (with my stage 1 porting on 044 round ports 40 x 35.5).
1916baja ·
http://www.cbperformance.com/ProductDetails.asp?ProductCode=3157
^^ they need work too Mick
sander288 ·
http://www.csp-shop.com/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=60331290317&rub1=Engine&rub2=Fuel%20System%2CIntake%20Manifolds%2CIntake%20Manifolds%20Type-1&artnr=13821a&pn=0&sort=0&all=
The CSP manifolds would be pretty close; but as Matt says if you really want to optimize an engines combination of parts they all need work
1916baja ·
matberry wrote:^^ they need work too Mick
Yeah,I just pointed them out as they don't require welding... He asked for something with more meat, they have more meat.
psimitar ·
Um, somewhat off topic guys but I was just wondering why I always see dyno graphs in Oz with Kilometer as the x axis? I was always used to RPM scaling in the UK and so confused how you know at what rpm the motor is producing what power?
Otherwise, interesting thread 🙂 I never knew the max HP was that closely related to head max CFM. Nice baseline to go on when playing with heads and manifolds 🙂
Sides ·
RAW069 wrote:132 rwhp is pretty decent from a 1915... what heads/carbs did you have
044 Wedgies, tall manifolds, 44 IDF's with 38 vents, FK87 and 11:1 compression. Stacks only.
Same engine but EFI with twin 48 IDF style throttle bodies and sequentional inj took to the number to 142
RAW069 ·
matberry wrote:There certainly a lot to consider, I agree that the intakes are an area for improvement. I have built a few 2165s and around 100hp is common, but with smaller cams and less compression so certainly something is amiss with your package. What deck height have you set?
I'm using 1.1 rockers, single HD spings and HD Aluminium Pushrods.
Could the geometry of how the rocker/pushrod length has been set up come into play with reduced lift? How can I check this if it is an issue?
I can adjust the valve etc as per normal.
RAW069 ·
Decent! Good work. Gives me a good indication.
RAW069 ·
psimitar wrote:Um, somewhat off topic guys but I was just wondering why I always see dyno graphs in Oz with Kilometer as the x axis? I was always used to RPM scaling in the UK and so confused how you know at what rpm the motor is producing what power?
Rpm's can be calculated from gear ratio, ring and pinion ratio and tyre diameter. There are also some easy calculators online.
This is where things get tricky. Ask 10 different engine builders and you'll get 10 different answers.
For me, wjth a W120 and your heads I'd definately be using dual springs, also, yes, geometery can certainly be responsible for reduced lift, also premature valve and guide wear. I've seen over 1mm of valve lift gain by changing/rectifying geometery.
psimitar ·
Which I get but dunno why the dyno place can't do this on the graph?
Sides ·
psimitar wrote:Which I get but dunno why the dyno place can't do this on the graph?
I guess combination of time, laziness, owner not having ratios handy etc etc.
You're right tho - in a perfect wold dyno graph would show hp vs rpm, ftlb vs rpm and AF vs rpm... then we'd all be comparing apples !!!
RAW069 ·
Ok guys, latest thinking.
I obviously need more air into the engine.
There are a couple of things I could look at with the current setup being:
- More porting on existing manifolds
- Bigger venturis
- More porting on heads - I don't think this is worth the expense, and am probably better off purchasing CNC ported heads that are fit for purpose rather than $$ on existing - then I can sell my current heads to someone that wants this level of power.
So what I am thinking is, as I was looking at pulling the motor down anyway and performing a level of blue printing and doing all the check that will instill confidence in the motor, I might invest in / start collecting bits:
- New set of heads, looking at DRD L6 heads
- FK89 cam
- straight cut cam gears
- new pushrods (chromoly)
- 1.4 rockers/solid shafts
- match ported manifolds by DRD with the heads
- bigger venturis on my 44 IDF's - maybe 40mm??
- keep the CR at 9:1 (thoughts??)
What are the thoughts with this setup??
I still want it drivable, but am happy to sacrifice some drivability such as rough idle etc.
And I want my power say from about 2500 - 3000 up to below 7000 rpm.
cnfabo ·
thats a damn big cam, you wont need that....is this a street engine, occasional blast at the drags??
cheers fabo
hellbugged ·
Did you see this...?
http://forums.aussieveedubbers.com/viewtopic.php?tid=25222&page=1
I think your doing fairly well with that cam in there
cnfabo ·
hellbugged wrote:Did you see this...?
I think you are right damp, nothing wrong with 106hp🙂
Sides ·
Umm... W120 with 1.1's to an FK89 with 1.4's is a pretty damn big jump... you realize that's like an extra .150 in overall lift ???
Wouldn't come onto power till fair bit higher than your 2500-3000 I'd think too...
I'd be looking at both the manifolds and tune first, especially if engine is "brand new" as you said in original post.
In all seriousness, how does the car drive as is... is it spot on everywhere, good temps, economy etc... or is it becoming more about the number ?
RAW069 ·
That is a great thread, cheers. Good benchmark and good food for thought - Cheers
RAW069 ·
Sides wrote:Umm... W120 with 1.1's to an FK89 with 1.4's is a pretty damn big jump... you realize that's like an extra .150 in overall lift ???
Thanks for the feedback - I guess this is why I posted and sought opinion in the first place.
Why does everyone that wants more power want more power??
The other thing with the engine is that I am not 100% confident with the build quality. It has a deep knocking that seems to be half the rev, so I think it has something to do with the valve train/cam??? As well as an occasional higher pitch knocking coming from the right head size, more like a valve rotating/rocker noise. It is that it is intermintent that concerns me.
I have brought this up with the engine builder who says it doesn't sound like an issue and to just drive it and enjoy it. The thing is, I have never had an engine make these noises including those smaller engines that I have built.
I will not purchase a complete engine from o/seas again, although I knew and accepted the risk because when I did my sums I could not even import the parts to build a motor for the same as the complete engine!
So to be confident I want to pull the motor down and perform a level of blueprint etc. And then I thought well if I am in there anyway, what could I look at changing for some more grunt??
Perhaps the FK89 does sound a bit big....?
I only drive this on weekends, and it is a build in progress. once I have mechanicals in order I will strip the car for a full bare metal job.
Given this info, what should I be considering???
I appreciate all your feedback so far, very thought provoking and exactly what I was after!
Super1302 ·
I had my 2276 on the dyno and with a jet change and went from 75 atw to 105 atw on a slipping clutch, my tq was 178ft.lb with an oil leak fix who knows, but jetting is essential. At the moment I run a fk10 and is a great cam for the street if you are interested to know.
Hope you get some good headway.
BiX ·
One thing I found with my engines is also the old idea of area below the curve, not just the peak power. My 1999cc, has 130rwhp, but is a more peaky. I had a old 1776 with (guess) 70rwhp but had a good spread from 1500 to 5000 rpm. The 1776 motor in was easier to drive and more forgiving, though maybe not quite as fast. I used to be able to mash the throttle and the limit was power not traction, plus it was more forgiving in slower corners, both of which are great on the street. The new motor is better and probably point to point faster, but needs allot more work to keep it on song and going. Its a race motor for when (soon!) i get back on the track. If your motor is for street use, the peak power number isn't always the best thing.
Sides ·
BiX wrote:Its a race motor for when (soon!) i get back on the track.
6 years BiX... getting close to that magical 7 you liked to rib me about so much...
vassy66T1 ·
BiX wrote:One thing I found with my engines is also the old idea of area below the curve, not just the peak power. My 1999cc, has 130rwhp, but is a more peaky. I had a old 1776 with (guess) 70rwhp but had a good spread from 1500 to 5000 rpm. The 1776 motor in was easier to drive and more forgiving, though maybe not quite as fast. I used to be able to mash the throttle and the limit was power not traction, plus it was more forgiving in slower corners, both of which are great on the street. The new motor is better and probably point to point faster, but needs allot more work to keep it on song and going. Its a race motor for when (soon!) i get back on the track. If your motor is for street use, the peak power number isn't always the best thing.
Very good advice 👍
RAW069 ·
Thanks again for all the good advice.
A couple of things that I will look at to start with then;
1. Open up manifolds, tapered down evenly from the carb to the head
2. Is it worth me looking at the venturi size? Or should I leave this at 36mm?
3. I was looking at replacing the rockers as the builder used second hand and the adjuster feet are a bit worn too. Is it worth looking at using 1.25 ratio rather than the 1.1, is there much to gain with the W120 cam?
4. Also I am wondering what the valve clearance should be with HD Aluminium Pushrods. The builder recommended standard 0.006", but I have read elsewhere the W120 is designed for 0.004"??
RAW069 ·
RAW069 wrote:Thanks again for all the good advice.
For those that might be interested, valve lash according to Engle for the W120 and HD Aluminum Pushrods is 0.004".
Does anyone have any input regarding using 1.25 ratio rockers??
Cam
