High Temp resistant electrical wire
https://forums.aussieveedubbers.com/threads/101240/high-temp-resistant-electrical-wire
Lateral ·
Hi guys
I'm sick of wire that has been in the engine bay for some time and exposed to heat getting hard are nasty looking.
Does anybody know where I can get some heat resistant wire or is there some sort of high heat resistant "heat shrink"?
Regards
Greg
LUFTMEISTER ·
You can buy a fibreglass sheave that slips over the top and is heat resistant. RS components or element 14.
Lateral ·
Thanks mate
I was also believe that there is also wire that uses a high heat resistant silicone based outer coating...
snitz ·
Dont Know if this helps..but I used a Fibreglass waterproof braided sheath from an electrical wholesaler the brand is CABAC..it comes in various sizes but unfortunately doesnt come in a rainbow of colours..Its worth going into an Electrical wholesaler and ask to have a look through there catalogues..Anyway heres a pic of my wiring with the fibreglass sheath,heatshrinked ends and waterproof connectors..cheers Snitz 🙂
vwo60 ·
Yes you can get a silicone insulated wire, i used to use it on fire fighting systems, i think i still might have some at home some ware.
http://www.ebay.com.au/sch/i.html?_trksid=p5197.m570.l1313&_nkw=silicone+insulated+wire&_sacat=0&_from=R40
Lateral ·
Thanks guys !
psimitar ·
Silicon coated wire is probably the best solution but the fibreglass heat resistant sheath can be got here Heat resistant sheath
cam070 ·
Intersting, the Cabac fibreglass sheathing is only rated to 180C, http://www.cabac.com.au/products/cable-management-and-fixings/fibreglass-sleeving/gs10 while the stuff from Jaycar is rated to 450C http://www.jaycar.com.au/productView.asp?ID=WS5504 but only seems to come in dia's up to 3.5mm
