Bobtail exhaust 4 into 1 V Merged collector slip fit style exhaust
https://forums.aussieveedubbers.com/threads/101286/bobtail-exhaust-4-into-1-v-merged-collector-slip-fit-style-exhaust
Anthiron ·
Basically aside of the Bobtail being more tucked in away from prying fingers. I am interested in what pros and cons there are to each system before I buy. Both seem to offer roughly similar ground clearance.
The engine will be most likely be a 1600 with a Bug Spray but will maybe be bigger once the car is back on (off) the road.
Bobtail style
http://www.chircoestore.com/catalog/popup_image.php?pID=4379&image=0
Slip fit Merged collector Style
http://www.chircoestore.com/catalog/popup_image.php?pID=4387&image=0
Nicko
The second one has way more ground clearance than the first, use the rear cylinder pipes as a guide, the merge one has everything above the heads, the 4-1 sits alot lower, hence, if you fit the merge system the cage and exhaust mesh will need re-engineering. (Smiley did this to one, also cut up the system to make it less obvious I believe)
The slip joints are a bit of a pain too, but deffo more power for an all out engine with the merge system.
Anthiron ·
Slip fit it is. Thanks Matt
Anthiron ·
Hey Matt. When you say the slip fittings are a pain, what exactly do you mean?
Smiley ·
They are a pain to get them all sealing right. I ended up welding mine all together and adding flange joints between #2 and #4 cylinders and the collector.
Check out Page 17 of my build for my initial fit.
Page 18 is where I cut it up. And page 19 where I welded all the bit back together.
http://forums.aussieveedubbers.com/viewtopic.php?tid=80275&page=17
If you have any questions don't hesitate to ask. 😀
Smiley 🙂
h ·
I have something similar to the first one on my beach buggy
it has slip overs that are gooped n clamped n it goes good for me
you are welcome to swing by for a lookisee if you want
just pm me
cheers pauly
I had one of these on my 1640 Baja...........great clearance, good performance and exhaust note 👍
http://www.cbperformance.com/ProductDetails.asp?ProductCode=3551
I have also used the slip joint systems too, but found it was very high at the collector and was hard to then cover with the cage (for rego).
Anthiron ·
Thanks H. I might do that if I remember when I am back from work.
I actually have posted the wrong picture for the first exhaust. That one uses J tubes. The bobtail style I am considering has the rear pipes up over the tappet covers. ClassicVeedub sell a stainless one.
After re-reading smileys thread I might go with the Bobtail.......Less hassle!
