I have a body off bare metal resto underway which requires some filler work and need some advise...After reading through several posts im planning to seal the blasted panels with 408 Epotec then apply body filler, seal and topcoat with 2 pac paint.
So here are my questions:
Does anyone recommend a particular brand of filler? There will be some largish areas covered on fenders and i'd like to use something that's as stable as possible and compatible with the epoxy primer.
The epoxy primer will be on the body for several months before filler work is done - will I have bonding issues? or will scuffing the surface with 120 grit be enough? I understand I should scuff the epoxy while its still fresh otherwise it will be much harder to cut into when fully cured?
Am I better off trying to do the bulk of the filler work straight after shooting the epoxy on for a better bond?
Will issues arise if the filler isn't sealed promptly?
I understand in a perfect world there'd be minimal time between each process but i'm doing this after hours and know at various stages the car might sit for several weeks/months without being touched....
Recommendations for two part sealers and paints?
All help appreciated 馃檪
Dubsky 路
