OK, So there is plenty of Engine info, not so much on the gearbox side of things. I just had a query that I was hoping you may be able to help me with.
Is it cheaper to by a Top end Swing axel box or rebuild the one I have?
The Syncro on my current box seems buggered as second and third can catch pretty badly when gearing down. So I'm currently weighing up my different options as I dont like doing or paying for things multiple times.
Box must take up to 400hp and accosiated abuse of daily driving and drag racing.
This figure is a guesstimate based on the future plans I have, which would be a worked 2332, I'd also like to know that if I wanted I could run a turbo and not need to replace the box. I've then allowed for abit more on top of that as insurrance haha.
Any help you can offer would be greatly appreciated.
Thanks,
John.
11CAB ·
What are your plans for the car? Registered?
You'll be flat out finding any vw drag beetles running 400hp, so I think your estimate is a bit high
Allbones ·
11CAB wrote:What are your plans for the car? Registered?
Will be a daily. Ive seen a few running injected turbo engines putting out 310hp or so. As I said the additional on top of that was "insurance".
Ultimately it will probably just end up with a 2332 in it. But I would like to know I have the reliability in the gearbox if I chose to go to a turbo set up later.
vwo60 ·
Have a talk to Dave Butler, he is the gear box guru that i use, he in on the gold coast, just search the forums to find him.
1916baja ·
"Dangerous" on here.. a gearbox to throw 400hp at, is a serious gearbox. Don't expect it to be cheap. And 400hp in a daily... Wow! I reckon you would have a smile from ear to ear every day with 150hp atw.
Allbones ·
1916baja wrote:a gearbox to throw 400hp at, is a serious gearbox.
Am I being too ambitious here? I was assuming that, given the amount of higher displacement engines out there that it didnt seem like such a feat.
What should I be aiming for with a 2332? (allowing for possible forced induction at a later date, money and time permiting.)
1916baja wrote:And 400hp in a daily... Wow! I reckon you would have a smile from ear to ear every day with 150hp atw.
I doubt I'll make 400hp, haha, I'd be happy at around 300-320 when I'm all done. If I can get 200+ out of the engine I get built and around 150rwhp or so i'll be stoked. That should put be somewhere close to a 12 second 1/4 pass right? haha
I'm just looking at gearbox now as it is slightly more pressing than a new engine and as much as I would love to throw $10000 at my car in one go, my wallet says otherwise, haha.
Is something like this reputable? What sort of bang for buck will I get?
There's a guy in nz with a box & engine combo for sale on here that may suit?
Again, see db, he built my box to handle the abuse my boosted ej20 will give it, but I also spent a fair chunk of coin...
If you're serious, see Dave 🙂
Fixed the rear drum yet? :P
Sides ·
Ummm, yeah - I think maybe you are being a bit ambitious... especially for a Swing Axle.
Taking a look through the dyno sheets thread (http://forums.aussieveedubbers.com/viewtopic.php?tid=25222) will give you some idea, but basically 2332 non-turbo I'd be thinking 140+ rwhp without going too exotic, adding forced induction say maybe 230 rwhp ?
For comparison most of the turbo subaru guys aren't anywhere up near 400hp... maybe 270 rwhp and I think Wayne Penrose had maybe 430 rwhp from his turbo'd type IV, 2.8 something litre... which is definitely a race engine and by no means a daily.
Either way rather than Swing Axle start thinking bus box (5 rib), Albins gearsets, good diff, and yeah... all that sort of stuff don't come cheap and is WAAAY above what you get in one of those Rancho boxes.
Allbones ·
Sides wrote:Ummm, yeah - I think maybe you are being a bit ambitious... especially for a Swing Axle.
I was only referring to 400hp, not rwhp, should have clarified earlier sorry. 😊
What is the limit of a swing axel box? The only thing I definately want later down the track is the 2332. If i dont have the option to go forced induction I can deal with that.
STIDUB wrote:Fixed the rear drum yet? :P
Haha yes, everything is sorted now, cars all lowered and back on the road. I really need to get some photos and update my thread.
modulus ·
400 (flywheel) H.P. from a 2332 is 171 H.P./litre; allowing 20% gearbox losses, let's say 140 H.P./litre at the wheels.
After 10+ years of serious, well-considered development, Dave Butler is making ~ 100 H.P./litre at the wheels in his N/A drag beetle with a Type 1 motor. Bear in mind that this is a two-valve-per-cylinder, pushrod-activated motor.
A Yamaha R1 makes about 179 (flywheel) H.P. at 12,500 RPM, with 16 valves, DOHC and 12.5:1 compression ratio.
Are you planning on a DOHC configuration? How many valves per cylinder? How many revs? What compression ratio?
Before you throw money at a gearbox suitable for a "400 H.P." motor, it's best to do the basic math to see whether that is in the realm of reality.
hth
1916baja ·
STIDUB wrote:There's a guy in nz with a box & engine combo for sale on here that may suit?
I bought most of the engine gear and the box sold...
hellbugged ·
Build and drive the motor first.... Then you will know what gearing you will need and for how much HP
Allbones ·
hth
Didnt mean to ruffle any feathers.
I do realise 400 from a 2332 is unlikely/not possible, as I said in my second comment in the thread.
The reason I stated that is because I wanted a strong box, something I don't have to worry about every time I drop the clutch. I was just thinking reliability.
Thank you to those who commented though. Will look into Dave Butler, seems to be the go.
Allbones ·
hellbugged wrote:Build and drive the motor first.... Then you will know what gearing you will need and for how much HP
Problem is the syncro in my box is muffed already. Sick of gears catching every time I gear down.
I was just trying to get it sorted to begin with rather than pull the box out, rebuild it, then 12 months down the road have to pull it out and build it again.
barls ·
this is possibly the biggest hipo engine ive seen and its still no where near 400Hp
just pointing it out thats all.
hellbugged ·
If you are running a stockish motor, then rebuild your stock box. When it's time for the big motor and box, a standard rebuilt one will be easy to sell for good money.
Effectively a box built for performance is almost entirely parts that you will buy new..... Expect to pay at least $4k .... And up depending on spec$
Search some of dangerous posts and take note of the hours and hours of labour necessary to make a strong gearbox.... $$$$
SuperOwen ·
400hp is doable with a turbo setup, not easy but quite possible. If your going all out then a Kombi box may be a better solution long term, although that means going IRS. You can do a Folts swinglaxle conversion, not sure if theres any reason you can't in a street car?
whathaveidone ·
I just built a swing axle box with rino case and full set of albins gears and alloy spool. Very expensive but should handle anything i can throw at it!!!!
bajachris88 ·
Have you considered subi gears?
SuperOwen ·
whathaveidone wrote:I just built a swing axle box with rino case and full set of albins gears and alloy spool. Very expensive but should handle anything i can throw at it!!!!
