bugmaniaar wrote:Hi all
I have a 63 bug and the wiper arms seem to have too little pressure pushing against the windscreen.
Is there anyway to increase the pressure that they push against the window??
Thanks,CC
the spring or tension piece is probably too weak...
so, just gently pend the arm in to the windscreen ..
that should put more pressure on it..
or replace the wiper arms with those off a 1968 beetle
which has proper spring tension and proper wiper blades
and the shaft is the same size..
so they just fit on and tighten up the grub screw...
