fuel Injection set up- photo added!
https://forums.aussieveedubbers.com/threads/101417/fuel-injection-set-up-photo-added
aintgotitmusthaveit ·
Never used brand new weber bolt pattern throttle body similar to injection perfection throttle body for fuel injection set ups. Throats are 50mm diameter
Take a look at http://www.injectionperfection.com/
If you are setup now with a a single weber (NA) or boosted, unbolt your weber and bolt this throttle body on!
It comes with TWO chrome fuel rail and 4 red injectors (red injecters off an RX7 (these alone are worth more than the sell price of the lot!
Also included in a microtech MT4 fuel only ecu
Matching Loom all brand new
A hand held controller for the MT4 ECU
Ecu manual is included
Beauty of this is you dont need new manifolds- your existng dual port manifolds will suffice as your injecting into the throttle body.
Also comes with an aluminium plenum with built in ventury shaped intakes.
All items (except the injectors) are new.
I'm loosing interest in tinkering so its up for sale.
Its is by no means a complete kit, but for those wanting to go injected on a big HP motor (good for upto 400HP easy!)its a great start. you will still need to source a Throttle position sensor, fuel injection clips and swirl pot fuel injection pump and some other bits but is a great start with quality gear and minimal if any fabrication required. PS there is no base map- dyno time is likley to get you to run
$720 or nearest offer
Pick up from West melbourne or can post to you
PM me email address for photos, or call me Nick on 0410461072.
fish26 ·
pm sent
So is that a single dual throttle body?
Yep
It's a single dual throat just like a weber dcoe, idf ida or dellorto equivalent
Here is a photo of th bits
I also found a 4AGZE Throttle position sensor that I will throw in
There were some solenoids in the kit also that I forgot about
I suggest you check out injection perfections link and prices- you will see that this is an absolute bargain at 700 compared to replacement value!
http://i1274.photobucket.com/albums/y430/aintgotitmustahaveit/efi_zps0c7a0d18.jpg
DubCty ·
I'll take it, If your happy to ship to Tassie thanks, Will call tommorrow
Cheers AL
DubCty wrote:I'll take it, If your happy to ship to Tassie thanks, Will call tommorrow
Cheers AL
All yours Alistair
I've smsd you bank details
I'll cover the postage
