Trouble removing Flex Plate
https://forums.aussieveedubbers.com/threads/101570/trouble-removing-flex-plate
satori ·
Hi all. Im trying to remove a flex plate off a 2.1 wasser and replace it with a fly wheel. The 5 hex head boilts just wont budge. Tried with a impact wrench but with no results. and with a long wrench with a hex head socket but almost stripped them. Any ideads.
donn ·
Drill the heads off? once the load is off then the remainder of the bolt should be able to be removed easily.
^^Unless they've been loctited???
Heat and replace bolts
ragged ·
Get a better quality socket. You will find heavy duty sockets only have 6 flats to contact the bolt head.
Dave
vlad01 ·
ragged wrote:Get a better quality socket. You will find heavy duty sockets only have 6 flats to contact the bolt head.
Dave
yes and long breaker bar.
those bolts I think are like 80 or 90 ft-lb so yeah thats tight for their size.
VolksVair ·
Daves on the money with a single hex socket, if you want to round bolts & nuts go the double hex, I allways use single hex to crack a bolt/nut then use the double hex to remove if its in a confined area
grumble ·
matberry wrote:^^Unless they've been loctited???
And use the single hex,the heat will help crack the loctite.
