Hey Air-heads,
I have installed J-pipes on the 1600 TP i have just finished rebuilding. when running, the fan housing pushes air over the heads and also into the exhaust/heat exchanger. now that i dont have a heat exchanger, the air will blow over the heads and straight into the street below.
question.
if you install j-pipes, is it common practice to block up the heat exchanger duct. and what method do you use to block it? (rubber + hoseclamp?).
result.
i assume that all that will occur is that more of the air will be routed to blow over the heads.
appreciate you insight.
Before:
After:
Pfeffernuss ·
