Thinking of fitting a CHT gauge.....any ideas of which is good, and which is not, and where to buy?
1916baja 路
Pierside parts has a vdo kit for $130 plus shipping... I have been looking into them also and I believe the catch is a lot of the gauges only go up to 300 c and I think we generally run higher head temps than most thus requiring a gauge that reads up to 600c like the vdo. I'm only guessing though. 馃槀
I've been using the above VDO gauge for over 10 years with no problems.
Its common to see 350-400deg F on the racetrack so get a gauge that reads up to 600.
66deluxe 路
I got my set up from aircooled.net. It works well. I am yet to see 350F on my guage the highest it has read after a full half hour of racing at Lakeside was around 250F which is where its stays even when normal street driving. I am running a type 4 engine. Bloody thing never gets hot.
HappyDaze 路
Thanks for the feedback, fellas.....looks like the VDO kit is the go.馃憤
Sides 路
Bit late to the party I know Greg, but yeah - the VDO kit is def the way to go. I run two of 'em on Jezzi (one for #1 cyl, and one for #3) and they work a treat.
Usually sit around 330F or so, and only just make it up to 350F towards the end of a multi-lap sprint (if I've really been on it).
馃憤
HappyDaze 路
How do you get time to look at TWO of 'em, Dave?馃槀
What sort of variation between 1 & 3?......I intended to fit only one sender, as I assumed #3 would be the hottest. Is the spark plug attachment OK, or would it be better to fix it to the head?
Sides 路
Heh heh - old pilot's trick Greg... gauges are mounted side by side and rotated slightly so when "normal" the needles point straight up... makes it real easy to spot anything non-normal just from a quick scan.
Plus it's known that I don't drive very quick, so I've got plenty of time.
馃槀
I have a DTM shroud and only see about 10-15F variation between 1 and 3 (and 3 is the hottest obviously)... but when up in the revs for extended time the variation comes down to basically nothing.
I used to have the senders under the plug but found it was a pain when changing/checking plugs, so now have them fixed direct to the head.
Craig Torrens 路
I have mine attached to the headstud on No 3cyl.
1303Steve 路
Wow they have come down in price, I remember in 80s they were worth about $250 - $300.
Has anyone done a comparison between locating the sender under the spark and on a head stud?
Craig Torrens 路
I did a comparison, bugger all diff 馃憤
1303Steve 路
That's good, I guess your only looking for an abnormality to see if something has gone wrong
