Type4 412 914 distributor
https://forums.aussieveedubbers.com/threads/101871/type4-412-914-distributor
Burrelli ·
Can anyone tell me what the part numbers are for the correct distributor and vacuum can that came on the AT and AN 1.8 engines in the 1973-74 euro 412 and 914 with the 40 PDSIT carbs?
forry2000 ·
Vw 022-905-205S ?? Replacement 022-905-205P
Vac can 070085?
Burrelli ·
forry2000 wrote:Vw 022-905-205S ?? Replacement 022-905-205P
Vac can 070085?
Thanks for that forry I think those distributors have the same advance curve as the correct Distributor and are a good replacement.
I did some research and found carb system part numbers on a 914 1.8v (v means carb) start with VW part number 021.
022 = EFI parts
021 905 205S is the distributor. I don't know the difference between it and the 022-905-205S and 205P
Found the Porsche/VW number for the Vacuum can 021905271H
Bosch number for the Vacuum can could be 070085.??? But I can not find any info on that.
