I am after a camber control arm or rear sway bar to suit a swing axle type beetle
Newcastle Area
vwo60 ·
Be carefull fitting a sway bar to a swing axle rear end, the bar actually promotes rear wheel tuck, a camber compensator is made for a swing axel rear end http://www.piersideparts.net/MB9615.html
whathaveidone ·
Rod Penrose has some going cheap at the moment!! Get in contact with greg mackey(happydaze). He is a wizz on swing axel tuning. had the pleasure of seeing his setup recently. He should be able to point you in the right direction!!!
gotthebug65 ·
vwo60 wrote:Be carefull fitting a sway bar to a swing axle rear end, the bar actually promotes rear wheel tuck, a camber compensator is made for a swing axel rear end http://www.piersideparts.net/MB9615.html
cheers that clears that up in my mind
gotthebug65 ·
whathaveidone wrote:Rod Penrose has some going cheap at the moment!! Get in contact with greg mackey(happydaze). He is a wizz on swing axel tuning. had the pleasure of seeing his setup recently. He should be able to point you in the right direction!!!
is that the camber compensator he has going cheap ?
HappyDaze ·
Fitting a 'camber compensator', without re-setting the rear torsion bars would be a waste of time.
gotthebug65 ·
HappyDaze wrote:Fitting a 'camber compensator', without re-setting the rear torsion bars would be a waste of time.
cheers for the tip
cnfabo ·
Wayne races a swing axle rear with a sway bar to success and I have also driven one as well and that are fine. Off the shelf camber compensators suck unless you build a mackie one, but more work then just bolting up a sway bar...my 2c
Fabo
vwo60 ·
I had sway bar on a swng axel car for about twenty minutes, took it off after a big dose of oversteer when the rear axels tucked mid corner, as for the available camber compensators, i have run these for years on both of my swing axel cars wiith out the sudden death oversteer that a sway bar promotes. Have a think how a sway bar operates, most manufacturers do not recommend fitting them.
HappyDaze ·
There is a bit more to improving the swing-axle suspension than just 'whacking on' a compensating spring, or anti-roll bar.
If a lot of power is involved, lack of traction could be a problem with an anti-roll bar. A limited-slip diff. would probably be needed.
After a bit of work on the rear suspension, understeer could rear its ugly head. Then you can work on the front end.......and so on.👍
gotthebug65 ·
HappyDaze wrote:There is a bit more to improving the swing-axle suspension than just 'whacking on' a compensating spring, or anti-roll bar.
i found a good article on aircooled that talked about similar facets of swing arm suspention
