Aussieveedubbers 路 Tech Talk
Mounting electric fuel pump on Type 3 beam
https://forums.aussieveedubbers.com/threads/101909/mounting-electric-fuel-pump-on-type-3-beam
bus914 路
Can anyone show me a photo of an electric fuel pump mounted on a type 3 beam?
bus914 路
I'm using a techometric switch to control the pump: http://www.revolutionelectronics.com/12003-installation.pdf
Here's how the Carter pump is mounted... If there is a better way let me know 馃シ
68AutoBug 路
Looks OK to Me..
why did You want to put it on the beam though??
I thought a body mount would have been normal.. lol
unless You don't have the body on...
bus914 路
A couple of reasons... right or wrong.馃檪
1. On the beam to keep any vibrations isolated. I think the factory efi pump was there for this reason.
2. On the cabin side considering everything in front of the beam a kind of crumple zone.
3. I didn't want to drill any holes into the bulkhead to reduce risk of rust. Type 3's drain the air boxes there hence it would often be wet.
vlad01 路
you could get a factory EFI mounting plate like this.
This one was also moved over to the middle to make room for an aftermarket pump.
bus914 路
Thanks. I saw that. There's a guy on Samba selling some too. But if/when the hose clamp lets go I'll probably just make my own plate to fit the centre properly.
vlad01 路
another alternative it to make a aluminum plate to take place of the tunnel cover and utilize that as a mounting plate. This guy went one step further and cast a one piece cover and pump mount. 馃憤
brilliant!
