can anyone recommend what window seals to use? my current ones are holding water and need replacing.
can anyone recommend a certain brand ?
cheers in advance
Kent ·
https://forums.aussieveedubbers.com/threads/101921/window-seals
Kent ·
Birdman ·
what do You mean by holding water??Kent wrote:can anyone recommend what window seals to use? my current ones are holding water and need replacing.
cheers in advance
Kent ·
I have water seeping into the cabin at my feet, that's what I meant by holding water, but I am removing the windows to get a new roof lining put in, so I will be replacing the seals for I have not a clue as too how old or the quality of the seals that are in there.68AutoBug wrote:what do You mean by holding water??Kent wrote:can anyone recommend what window seals to use? my current ones are holding water and need replacing.
cheers in advance
front and rear screens actually have holes in the two bottom corners for the water to run out of...
black silastic carefully squuezed under the rubber should stop any water seepage... and seal the rubbers..
to the body or the glass...
