G'day!
I been reading through aircooled.net's catalogue about the use of high volume oil pumps and using thinner oils to maintain same typical stock oil pressure (to not overpower the relief system), but the combo apparently results in increased oil volume/flow rate for cooling bearings etc.
Is this worth while for a hypo motor? If say i had a 30mm or 32mm oil pump, how low a viscosity oil would you go?
Thanks,
Just shopping around 馃檪
Chris.
bajachris88 路
